Vpn access - rut901
  • Yes i can access RUT901 WebUI remotely via the link on “d”
*Lan Forwarding is enabled in the RMS VPN → VPN hubs → Routes
  • Yes, I do restart the hub after adding a route
  • When I’m locally connected in the subnet with the tektonika I can ping my device’s IP address, but I don’t see my devices on Teltonika WebUi Lan interface or on the “window ports”
*I can’t find this in Network Firewall. The only tabs are : Port Forwards / Attack Prevention / DMZ
I still have the same problems : I can’t detect my equipments…
If you want to see my configuration I’m on the account clement.grange@equans.com
