View Events Log SSH - RUT*
Hello, Is there any way to view the events log via SSH?
Good afternoon,
Yes, you can view the events log of a Teltonika router via SSH. After connecting to the device using SSH, you can use the following command to read the system logs:
logread
If you want to monitor logs in real time, use:
logread -f
To filter logs for specific events (for example, OpenVPN-related entries), you can use grep:
logread -f | grep openvpn
This will show only log entries containing “openvpn”.
Regardsm
Arturas
