I am experiencing a very large latency when pining router from clients on LAN (and the other way around).
My network topology is:
10.2.1.1 - RUTX10 router
10.2.1.2 - client A connected to LAN1 on RUTX10
10.2.1.3 - client B connected to LAN2 on RUTX10
Both client A and client B experience very high latency when pining RUTX10, and a similar behaviour is observed when pinging from RUTX10 to A and B
ping 10.2.1.1
PING 10.2.1.1 (10.2.1.1): 56 data bytes
64 bytes from 10.2.1.1: icmp_seq=0 ttl=64 time=348.663 ms
64 bytes from 10.2.1.1: icmp_seq=1 ttl=64 time=295.658 ms
64 bytes from 10.2.1.1: icmp_seq=2 ttl=64 time=72.992 ms
64 bytes from 10.2.1.1: icmp_seq=3 ttl=64 time=12.697 ms
64 bytes from 10.2.1.1: icmp_seq=4 ttl=64 time=27.885 ms
64 bytes from 10.2.1.1: icmp_seq=5 ttl=64 time=32.420 ms
64 bytes from 10.2.1.1: icmp_seq=6 ttl=64 time=63.559 ms
64 bytes from 10.2.1.1: icmp_seq=7 ttl=64 time=129.821 ms
64 bytes from 10.2.1.1: icmp_seq=8 ttl=64 time=229.339 ms
64 bytes from 10.2.1.1: icmp_seq=9 ttl=64 time=260.018 ms
64 bytes from 10.2.1.1: icmp_seq=10 ttl=64 time=0.652 ms
64 bytes from 10.2.1.1: icmp_seq=11 ttl=64 time=0.769 ms
64 bytes from 10.2.1.1: icmp_seq=12 ttl=64 time=0.716 ms
64 bytes from 10.2.1.1: icmp_seq=13 ttl=64 time=233.976 ms
64 bytes from 10.2.1.1: icmp_seq=14 ttl=64 time=347.060 ms
However, both clients can ping each other perfectly:
ping 10.2.1.2
PING 10.2.1.2 (10.2.1.2): 56 data bytes
64 bytes from 10.2.1.2: icmp_seq=0 ttl=64 time=1.300 ms
64 bytes from 10.2.1.2: icmp_seq=1 ttl=64 time=1.125 ms
64 bytes from 10.2.1.2: icmp_seq=2 ttl=64 time=1.045 ms
64 bytes from 10.2.1.2: icmp_seq=3 ttl=64 time=1.049 ms
64 bytes from 10.2.1.2: icmp_seq=4 ttl=64 time=1.149 ms
64 bytes from 10.2.1.2: icmp_seq=5 ttl=64 time=1.285 ms
64 bytes from 10.2.1.2: icmp_seq=6 ttl=64 time=1.025 ms
64 bytes from 10.2.1.2: icmp_seq=7 ttl=64 time=1.342 ms
64 bytes from 10.2.1.2: icmp_seq=8 ttl=64 time=2.206 ms
64 bytes from 10.2.1.2: icmp_seq=9 ttl=64 time=0.991 ms
64 bytes from 10.2.1.2: icmp_seq=10 ttl=64 time=1.133 ms
64 bytes from 10.2.1.2: icmp_seq=11 ttl=64 time=1.203 ms
64 bytes from 10.2.1.2: icmp_seq=12 ttl=64 time=1.055 ms
64 bytes from 10.2.1.2: icmp_seq=13 ttl=64 time=1.442 ms
64 bytes from 10.2.1.2: icmp_seq=14 ttl=64 time=1.026 ms
The later observation should eliminate any hypothesis about damaged network cables. The only way how A and B can communicate is via network switch on RUTX10. Something fishy must be happening in RUTX10 itself.
It also does not seem that RUTX10 is overloaded:
Mem: 162148K used, 85780K free, 524K shrd, 52K buff, 31144K cached
CPU: 2% usr 0% sys 0% nic 95% idle 0% io 0% irq 2% sirq
Load average: 0.04 0.20 0.22 2/120 6017
Other observations: RUTX10 is connected to another client āCā using WireGuard tunnel. It seems that one can ping āCā from within RUTX10 perfectly, much faster than any clients on LAN:
ping 10.1.1.1
PING 10.1.1.1 (10.1.1.1): 56 data bytes
64 bytes from 10.1.1.1: seq=0 ttl=64 time=2.390 ms
64 bytes from 10.1.1.1: seq=1 ttl=64 time=2.624 ms
64 bytes from 10.1.1.1: seq=2 ttl=64 time=1.849 ms
64 bytes from 10.1.1.1: seq=3 ttl=64 time=1.905 ms
64 bytes from 10.1.1.1: seq=4 ttl=64 time=2.449 ms
64 bytes from 10.1.1.1: seq=5 ttl=64 time=1.986 ms
64 bytes from 10.1.1.1: seq=6 ttl=64 time=2.081 ms
64 bytes from 10.1.1.1: seq=7 ttl=64 time=1.792 ms
64 bytes from 10.1.1.1: seq=8 ttl=64 time=2.222 ms
64 bytes from 10.1.1.1: seq=9 ttl=64 time=2.086 ms
64 bytes from 10.1.1.1: seq=10 ttl=64 time=2.083 ms
64 bytes from 10.1.1.1: seq=11 ttl=64 time=2.149 ms
64 bytes from 10.1.1.1: seq=12 ttl=64 time=1.856 ms
64 bytes from 10.1.1.1: seq=13 ttl=64 time=2.413 ms
64 bytes from 10.1.1.1: seq=14 ttl=64 time=2.060 ms
^C
--- 10.1.1.1 ping statistics ---
15 packets transmitted, 15 packets received, 0% packet loss
I simply can wrap my head around - if one assumed that RUTX10 was overloaded, why would it have an easier time pinging remote client C over a WireGuard tunnel than any clients on LAN?
As things stand, at the moment I am clueless as how to troubleshoot the problem. Any help would be much appreciated.
