Regarding WiFi WAN in both rutx50 and rutm50 router
, looking in diffrent guides, i see mention of the relayed package needed for the use of wifi wan. in other cases for updated Firmaware I see no mention at all. do I actually need it to establish a WIFI Wan connection between routers?
is there any difference between the RUTX50 and RUTM50 configurations/ability to use WiFi WAN?
When it comes to just configuring WiFi WAN on your RUT routers, there’s no need to install and/or configure Relayd. Just make sure that the LAN subnet of the routers are different to avoid some IP issues. (LAN of RUTM50 will be the WAN of RUTX50).
Relayd is just used to bridge the WiFI WAN network to the LAN devices. (nodes connected to the LAN port of the Router WiFi client will have the IPs of the WiFi AP).
Unless this is your requirement, there’s no need to configure it.
In that case, yes you will need to install the Relayd package when it is not installed yet, then configure it so LAN devices (with DHCP enabled) will have the IPs of the WAN network.
Just make sure that the DHCP is disabled on the actual router.
