Using TSW110 and RUT241 with external power supply
Hello !
I would like to use TSW110 and RUT241 and due to restricted space an a separate DIN rail 12V power supply, which I need anyway.
Are there any specific requirements in terms of EMC immunity ?
How is the EMC immunity specified, when using the PSU coming with the devices? EN IEC 61000-6-3 or EN IEC 61000-6-2 ?
Thorsten
Thank you for reaching out.
Our power supply units that come with the devices such as TSW110 and RUT241 do not have EN IEC 61000-6-3 or EN IEC 61000-6-2 certifications yet, so there are no specific requirements in terms of EMC immunity.
If you want to power up these devices with a third-party power supply, please make sure that you choose a power supply of high quality. Some power supplies can produce voltage peaks significantly higher than the declared output voltage, especially during connection and disconnection.
These two devices also have the option to be powered by passive PoE via LAN1 port.
Please refer to these powering guides :
I hope this information helps.
Arnoldas
