Hi All:
We have an app that required old FW on an RUT950. Problem is, the openwrt guys have moved the packages to the archive which is an https server so the included wget can’t update using opkg.
I have used curl to copy the https://archive.openwrt.org/chaos_calmer/15.05.1/ar71xx/generic/packages/packages/Packages.gz file to the /root directory. How can I force opkg to use this local file to update the routers package list.
We need to install the openssh-sftp-server
cheers,
John
