Using both directional and omnidirectional LTE antennas on RUT955
Hello, is it possible to connect both those types of antenna to a RUT955?
This because sometimes the only cell pointed by my directional LTE antenna dies and I’m lost.
How can this be done, simply connecting one wire of each antenna to one of the RUT955 mobile signal socket?
Gian
Thank you for reaching out.
Yes, it is possible to connect both antennas. In your case, try connecting the directional antenna to the Main Antenna SMA connector and the omnidirectional antenna to the AUX connector.
