I would like to connect a third-party device to an RMS VPN hub via OpenVPN. Unfortunately, this client requires a username and password. Is there a solution for this? Can I define a username and a password?
Thanks for your help!
Could you clarify what you mean by “client requires a username and password”? Are you referring to the third-party device? For RMS VPN Hub specifically, you’re not required to have any usernames or passwords set up in order to reach end devices; If the end devices has some type of login page, reaching it’s IP address via a specific port (if required) should redirect you to the page automatically.
You can find more information on setting up the RMS VPN Hub here: RMS VPN Hubs - Teltonika Networks Wiki
