I have a user group “user” with user name “status”. The group has read permissions as follows: status/overview and services/gps/map
Status/overview view works fine but for some reason services/gps/map does not show the location data with the latest version of RUTX_R_00.07.06.6. For example RUTX_R_00.07.05.4 firmware version the data is visible when using “read” access.
Could you please clarify if the page does not load at all, or you do not have access to the Services → GPS → Map page? Or perhaps the map loads, but it does not show the location?
Was it working properly before v7.06.6? If so, which firmware version was installed previously?
Did you update the firmware with ‘keep settings’ option enabled?
Yes, I can download the page, but the location information data cannot be displayed. This worked fine with version 7.05.4, for example. If I allow the main level services/gps permission, then services/gps/map location is displayed. And yes, I updated with “keep setting” option.
