Use case for shrimp transport boxes with Eye Sensor
I have a use case to validate. I am setting up one Eye Sensor on the top plastic cover of a big plastic box (1m x 1m x 1m). We cannot install magnets. We can only install Eye Sensor by itself.
I have tested two Eye Sensor (roll & pitch events + temperature) installed on the cover of two different plastic boxes that contains ice and shrimp. I need to detect ON EXIT or HYSTERESIS events when someone opens this big box. I used a GH5200 with standard bluetooth 4.0 Eye Sensor configuration using MAC address.
Use cases: Smaller trucks transport 2 to 4 plastic boxes. However, some of then transport until 20 boxes (10 by 2 array) on the same truck. I need to detect all the possible events of NON authorized open box.
Question#1: How can I detect using a GH5200 or FMCXXX tracking device all these 20 units and having all the readings of all possible sensors? What is the correct Bluetooh setting and IO table preset?
Question#2 : I cannot pair each time that a truck leaves factory with a preset pair of boxes. Operation is a caos and the boxes assignation is random. Is there a possible configuration that the installed FM device or GH5200 can read ANY eye sensor and still reading roll&pitch values and be able to send to my server?
Welcome to Teltonika Community Forum :slight_smile:
Question#1: How can I detect using a GH5200 or FMCXXX tracking device all these 20 units and having all the readings of all possible sensors? What are the correct Bluetooth settings and IO table preset?
  • On the FMCXXX/GH5200 devices we have an option to connect multiple Eye Sensors more than 4 however parsing the data from the device might be challenging. You may refer to the links below to learn more about the parsing of records.
Eye Sensor Parsing Data: EYE SENSOR / BTSMP1 - Wiki Knowledge Base | Teltonika GPS
Question#2 : I cannot pair each time that a truck leaves factory with a preset pair of boxes. Operation is a chaos and the boxes assignation is random. Is there a possible configuration that the installed FM device or GH5200 can read ANY eye sensor and still read roll&pitch values and be able to send to my server?
  • We have functionality to capture the Eye Sensor data through Beacon List where the sensors would be detected with additional information as required to be sent by the sensor. Still, you need to do some workaround on your Server end to receive the data from the sensor.
Advanced Beacon Capturing Configuration: Advanced Beacon Capturing Configuration - Wiki Knowledge Base | Teltonika GPS
I hope this helps.
Patrick
