USB stick not mounted after cold reboot RUTX10
I’m using a RUTX10 (firmware: RUTX_R_00.07.16.1) with a USB flash drive (SanDisk 128GB and 256GB, tested with both exFAT and FAT32) that’s used for local file access.
After a reboot (e.g. after a power cut), the USB stick is not mounted, and /dev/sda1 is not available. Even ls /dev/sd* returns nothing.
However, as soon as I physically reinsert the USB stick, it gets detected immediately and mounts correctly. From that point on it works without issues — until the next reboot.
Tried:
  • Delaying mounting attempts up to 300 seconds
  • Manually triggering USB detection (rmmod usb_storage; modprobe usb_storage)
  • Using startup scripts with block mount, mount, or hotplug logic
  • Forcing unbind/bind via /sys/bus/usb/devices/1-1.4/
  • mounting fails unless the USB stick is physically reinserted.
  • I confirmed the USB stick works fine in a PC and on this same router when manually replugged.
My question:
Is this a known issue on the RUTX10 - or other devices ?
And is there a recommended fix or workaround to ensure the USB stick mounts automatically after cold boot?
Thanks in advance!
edit 14:26
a friend says it works fine on a RUTX10 with firmware RUTX_R_00.07.12.3
any other suggestions ? can I downgrade to test?
Could you please let me know if the same issue persists with the latest 7.16.3 firmware version?
If you haven’t tested it yet, please do so — the firmware can be downloaded here: RUTX10 Firmware Downloads - Teltonika Networks Wiki
If the issue still occurs, please let me know so I can contact you privately to request a troubleshoot file.
Additionally, for testing purposes, you can try downgrading to 7.12.3. Please note that all router configurations will be lost during the downgrade. Therefore, I highly recommend creating a backup file beforehand. You can find instructions here: RUTX10 Maintenance - Teltonika Networks Wiki
Let me know how it goes or if you have any questions.
Sorry for the late reply due some holidays.. I downloaded and installed version 7.16.3 two weeks ago, and initially noticed the same problems. So, no improvement.
I also downloaded the latest version 7.17 today and am experiencing the same problem. It works as soon as I insert the USB drive after rebooting. But after rebooting, the USB drive isn’t recognized.
Please let me know how to proceed.
Thank you for update.
Could you please confirm if you have tried downgrading the router to 7.12.3 firmware version for testing purposes?
Bet regards,
No, sorry — I did not downgrade.
I am in a live (production) situation and do not have the time to lose all my configurations. –
Otherwise, we can postpone it for a few weeks, when I will have more time.
(If you think my situation is unique, and it should normally work with this firmware.)
For further troubleshooting, we will need some sensitive information from your device, such as a troubleshoot file. Since it is not safe to share this information on the community forum, I have sent a form to the email address you used to register. Once you fill out the form, I will contact you privately regarding this issue.
Please use the ticket ID “14917” when completing the form.
After installing firmware 7.17.1, this issue is resolved. The USB now mounts reliably after any boot or reboot. Thanks!
