Hello, I would like to upgrade the firmware of my rut955 (currently used: RUT9_R_00.07.03.4, wich is more than one year old than the latest version).
My concern is that after the firmware in updated, I can lost all the custom settings (wifi passwords, dynamic DNS configs and so on).
Is there any way to upgrade firmware without resetting the device?
Thanks Gianluca
No worries, you won’t lose your config if you upgrade through WebUI. Just make sure the “Keep Settings” toggle is ON.
Hi gianmasi,
When upgrading firmware version, we do have an option to keep settings. This allows the device to retain configuration on the update firmware. Make sure to enable keep settings when upgrading the device.
Let me know if this helps.
