I have several rut955 with EC25-EU modems.
I need to update them to version RUT9_R_00.07.05 because… there is finally a normally working NTRIP client.
However, I encountered a problem that on versions newer than 7.01.2 my mobile network stops working.
Modem software version - EC25EUGAR06A06M4G_01.005.01.005
I can’t update the modem because… The modem_updater package is not installed. I’m facing the “Unknown package ‘modem_updater’” error.
I also did not find this modem in the repository.
Can someone send me this package to update the modem?
Yes, that’s exactly what I do.
The ‘sshfs’ package is installed, but ‘modem_updater’ is not listed.
‘opkg list | grep modem_updater’ also does not show such a package.
I’ve tried many versions already. including RUT9_R_00.07.06.10_WEBUI.bin.
The newest one on which the gsm modem continues to work is 00.07.01.2, but this version does not have an NTRIP client.
And as a result of all the manipulations, I encountered a problem that ntrip stopped automatically connecting to the version that I used earlier RUT9XX_R_00.06.08.5. Resetting to factory settings does not help.
However, if I try to run ntripclient through the cli using the command “ntripclient -s ‘server’ -r ‘port’ -m VOLV -u login -p password -M n”, then it successfully connects to the server and accepts the amendment.
But here, too, I encountered the difficulty that I cannot transmit this correction to rs232.
When I specify -D ttyS0, the session starts, but I don’t see anything on rs232.
I also don’t understand how to force nmea to be sent via cli from the built-in GPS receiver.
“help” describes only the transmission of a fixed nmea string.
I get an error loading “vuci”
I also don’t see this directory through the browser.
Downloading https://downloads.openwrt.org/releases/21.02.0/targets/ath79/generic/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_core
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/vuci/Packages.gz
*** Failed to download the package list from https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/vuci/Packages.gz
Collected errors:
* opkg_download: Failed to download https://downloads.openwrt.org/releases/21.02.0/packages/mips_24kc/vuci/Packages.gz, wget returned 8.
root@Teltonika-RUT955:~#
Just to clarify, these instructions were meant for version 07.xx.xx, not 06.xx.xx. Please make sure to update it to the 07.xx.xx version before downloading the modem_updater.
Also, I forgot to mention, have you tried updating the modem through the firmware update section in System → Firmware → Firmware update?
root@Teltonika-RUT955:~# rut_fota -i
[connect_to_server:79] error: Failed to resolve connection host IP address
[create_connection:39] error: Failed to connect to server
[main:477] error: Communication has failed
root@Teltonika-RUT955:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=115 time=62.358 ms
64 bytes from 8.8.8.8: seq=1 ttl=115 time=61.908 ms
64 bytes from 8.8.8.8: seq=2 ttl=115 time=61.993 ms
^C
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 61.908/62.086/62.358 ms
I installed all the updates via the bin file from the downloads page.
The configuration does not seem to be correct, you can try resetting it to default and test if it helps. Basically you can copy the default config with these commands:
