The instruction is:
If function is 16 - from 1 to 123 (first register + registry value can not go out of range), Registry values separated by commas without spaces. Example.: 1,2,3,654,21,789 . There has to be as many values, as specified number of registers, and each value must be between 0 and 65535 . If number of registries is 0, there should be no registry values
Unclear is what is meant by “from 1 to 123”. It appears that it has to do with “specified number of registers”, but what part of the example 1,2,3,654,21,789 is the 'specified number of registers?
