Whentrying to SSH in to RUTX50 I get the following message: ssh_dispatch_run_fatal: Connection to 192.168.1.1 port 22: unknown or unsupported key type
The error message ssh_dispatch_run_fatal: Connection to 192.168.1.1 port 22: unknown or unsupported key type
means that the SSH client and server cannot agree on a common key type for the connection. This issue can arise for a few reasons:
- Outdated Key Types: The SSH server might be using key types that the client no longer supports.
- Configuration Problems: The SSH client or server settings might be restricting or requiring specific key types that are incompatible.
Please update the SSH client on the device you are using to connect to the RUTX50. Additionally, ensure that SSH access is enabled on the RUTX50.
