Unable to reset TRB145
Hello there.
I am having a weird issue with 2 TRB145. I am unable to reset them both. The signal LEDs stay on after pressing reset for 12-20 seconds and nothing happens after that. I believe I was able to enter fastboot mode on the devices.
Any help would be greatly appreciated. This is quite urgent.
Just adding my device details:
Device 1: *********** - Batch no: 035
Device 2: *********** - Batch no: 021
Many thanks
Thank you for reaching out.
Could you confirm whether any LEDs light up on each TRB145 when you connect it to power?
Once each device has fully started, please press and hold the reset button while observing the five signal strength LEDs. Do they briefly go out and then light up one at a time, or do they remain steadily lit throughout?
One additional LED should light up every two seconds. When all five are lit, approximately 10 seconds have elapsed. Please continue holding the button for another five seconds, then release it at approximately 15 seconds in total. Upon release, all five LEDs should begin blinking together, indicating that the factory reset has started.
Please note that with the default settings, holding the button for longer than 20 seconds cancels the reset.
T.
Thanks for the response.
The device is working fine. It connects to a VPN server we have configured it to connect to. The LEDs behave in a weird way though. Signal bar LED 1 is lit. LED 2 is off, LEDs 3-5 are blinking while the unit is working.
During reset, the LED sequence above briefly go off, and start lighting up till all 5 are lit. Then LED 5 goes off, and all the others stay on. They remain on and nothing happens.
I have tried from 12, 13, 14 , 15, 16, 17, 18 ,19 ,20 seconds multiple times. I have reset RUT 955 and other teltonika devices successfully. And I don’t believe it’s an issue with the timing.
The units are all running a light python script too. If that detail helps.
Thank you
Could you please clarify whether you can currently access the device through the WebUI or via SSH? Are you trying to reset the device to regain access, or would you like to only clear its configuration?
T.
Hello Tautvydas.
We have lost the password and we need to reset the device to regain access.
Thank you
