In the new firmware the ubus call file list action doesn’t work via rpc.
It works perfectly file via ssh cli.
It doesn’t seem to matter what file path I set, I always get back ubus error code 6.
I’ve tried /root, /etc/config, /etc/vuci-uploads, /tmp
I’ve also tried multiple devices with different models and firmware:
RUT956 in the new fw RUT9M_R_00.07.04.5 (fails)
RUT300 in the new fw RUT30X_R_00.07.06.10 (fails)
RUT240 in the new fw RUT2_R_00.07.06.3 (fails)
RUT955 in the old fw RUT9XX_R_00.06.08.6 (works)
RUT240 in the old fw RUT2XX_R_00.01.14.7 (works)
curl --silent 10.2.1.4/ubus -d '{
"jsonrpc":"2.0", "id":1, "method":"call", "params":
"00000000000000000000000000000000", "session", "login",
"username":"admin", "password":"pw"
"402bbbd69e5bf9c0c110a7ee0beda937", "file", "list",
"path": "/etc/config",
{"jsonrpc":"2.0","id":1,"result":[6]}
I’ve noticed that the new firmware returns this acl in the response:
[file] => Array
[*] => Array
[0] => read
[1] => write
[2] => exec
[/usr/lib/opkg/info/pam.control] => Array
[0] => list
The list action is not the same as the read, write, exec actions, it mentions pam.control
why is this different and what can I do to make it behave properly?
