Tws202 - tsw2_r_00.01.07.1
Hi, can’t I remove vlan1?
I can’t understand if only vlan 10 and vlan 1001 (tagged) passes through port 7 or for some strange reason vlan 1 also passes? (I had a problem with another brand that starts with H and in the trunk ports with different vlans it was necessary to specify not to let vlan 1 pass (I had several problems before specifying this on the switch). Thank you very much
If your problem is untagged port7 in vlan1 then check out TSWOS 1.09. You can see fix in the changelog:
VLAN: fixed ports allowing untagged traffic when no untagged VLAN is configured
Hi Dainius,
Great! You’ve been very helpful! Thanks a lot and have a great day.
