TWS202 certificate
Hello Teltonika team,
I recently purchased a TSW 202 switch and I am trying to secure the network traffic by adding my own certificate. However, I encountered an issue while attempting to download the existing certificate from the system.
Here are the steps I followed:
  1. I navigated to System > Administration > Access Control.
  2. In the HTTPS section, I clicked on the “Edit” option and then tried to download the certificate by clicking on the “Download” link.
  3. Unfortunately, an error message popped up: “Failed to download certificate files”.
    Could you please assist me with this issue? I need guidance on how to successfully download the certificate file or alternatively add my custom certificate.
Thanks a lot
Hervé
Could you please specify the firmware version currently installed on your TSW202? If it is not the latest version (01.03.1), please update your device and check if the issue persists. You can download the firmware from this page: TSW202 Firmware Downloads.
Hello
My TSW202 is up to date
Thanks for your reply
I have sent you a form to fill out. Once completed, I will contact you privately regarding the troubleshoot file. Please use the ticket ID “10929”.
