I can only get one wireguard interface running at time, not both together.
I supposed to get both wg_CATT and wg_CATT_b interfaces in my routing table, but in command “route” I can only see one between wg_CATT or wg_CATT_b interfaces.
What’s wrong on my configuration?
Is it supposed to use more than une wg client at time?
Thanks.
Ok, script updated and tested on RUT200 RUT2M_R_00.07.13.2
Loading wireguard configuration file created by WireguardUI (let’s say FERR.conf for main and FERR_b.conf for server backup).
Usage:
./myscript.sh FERR.conf
Creating on /etc/config/network following wireguard interface and wireguard peer:
config interface ‘wg_ferr’
config wireguard_wg_ferr ‘pferr’
Created backup of network file with timestamp (date and time):
network_20250305_104138.bak
Wireguard interfaces disabled by default, to be manually enabled.
#!/bin/ash
#set -x
# Check for configuration file
if [ "$#" -ne 1 ]; then
echo "Usage: $0 wireguard_configuration_file.conf"
exit 1
fi
ConfigFile="$1"
Interface=$(basename "$ConfigFile" .conf)
MaxLen=7
# Validate interface name length
if [ ${#Interface} -gt $MaxLen ]; then
echo "Error: Interface name '$Interface' exceeds $MaxLen characters."
exit 1
fi
# Extract CLIENT parameters from [Interface]
Address=$(awk '/^\[Interface\]/ { intf=1 } /^Address/ && intf { print $3 }' "$ConfigFile")
PrivateKey=$(awk '/^\[Interface\]/ { intf=1 } /^PrivateKey/ && intf { print $3 }' "$ConfigFile")
ListenPort=$(awk '/^\[Interface\]/ { intf=1 } /^ListenPort/ && intf { print $3 }' "$ConfigFile")
# Extract SERVER (Peer) parameters from [Peer]
PublicKey=$(awk '/^\[Peer\]/ { peer=1 } /^PublicKey/ && peer { print $3 }' "$ConfigFile")
PresharedKey=$(awk '/^\[Peer\]/ { peer=1 } /^PresharedKey/ && peer { print $3 }' "$ConfigFile")
Endpoint=$(awk '/^\[Peer\]/ { peer=1 } /^Endpoint/ && peer { print $3 }' "$ConfigFile")
AllowedIPs=$(awk '/^\[Peer\]/ { peer=1 } /^AllowedIPs/ && peer { print $3 }' "$ConfigFile")
Keepalive=$(awk '/^\[Peer\]/ { peer=1 } /^PersistentKeepalive/ && peer { print $3 }' "$ConfigFile")
MTU=$(awk '/^\[Interface\]/ { intf=1 } /^MTU/ && intf { print $3 }' "$ConfigFile")
echo "MTU forced to 1420"
# di default 1450
MTU=1420
MTU=1280 # standard compatibile con molti servizi
# Validate required fields
[ -z "$Address" ] && { echo "Missing Address"; exit 1; }
[ -z "$PrivateKey" ] && { echo "Missing PrivateKey"; exit 1; }
[ -z "$PublicKey" ] && { echo "Missing PublicKey"; exit 1; }
[ -z "$Endpoint" ] && { echo "Missing Endpoint"; exit 1; }
# Split Endpoint into host and port
EndpointHost="${Endpoint%:*}"
EndpointPort="${Endpoint##*:}"
# Funzione per lowercase
to_lowercase() {
echo "$1" | tr 'A-Z' 'a-z' # Sintassi alternativa per BusyBox
# Convert to lowercase to be compatible with OpenWrt uci code
Interface=$(to_lowercase "$Interface")
InterfaceName="wg_$Interface"
# Check for existing interface
echo "Interface = $Interface"
echo "InterfaceNAme = $InterfaceName"
interface_exists() {
grep -q "config interface '$InterfaceName'" /etc/config/network
if interface_exists; then
echo "Interface '$InterfaceName' exists. Exiting."
exit 0
fi
# Check for existing interface parameters
# ma questa ricerca viene effettuata su tutto il file.....
parameters_exist() {
grep -q "option private_key '$PrivateKey'" /etc/config/network && \
grep -q "option public_key '$PublicKey'" /etc/config/network && \
grep -q "option endpoint_host '$EndpointHost'" /etc/config/network
if parameters_exist; then
echo "Interface with same parameters exists. Exiting."
exit 0
fi
# check for listen port on client side
ClientListenPort=51820
listenport_exist() {
grep -q "option listen_port '$ClientListenPort'" /etc/config/network
if listenport_exist; then
#echo "listen_port $listenport_exist already present."
while listenport_exist; do
ClientListenPort=$((ClientListenPort+1))
done
#echo "listen_port set to $ClientListenPort"
fi
# Generate UCI configuration
config_interface="
option proto 'wireguard'
list addresses '$Address'
$( [ -n "$MTU" ] && echo "option mtu '$MTU'" )
option disabled '1'
config_peer="
config wireguard_$InterfaceName 'p$Interface'
option preshared_key '$PresharedKey'
list allowed_ips '$AllowedIPs'
option endpoint_port '$EndpointPort'
$( [ -n "$Keepalive" ] && echo "option persistent_keepalive '$Keepalive'" )
#option route '1'
option route_allowed_ips '1' # aggiunta io dopo
# creo il backup del vecchio file di rete
timestamp=$(date +"%Y%m%d_%H%M%S")
#echo "$timestamp"
# Genera il nome del file
filename="network_${timestamp}.bak"
# Stampa il nome generato
#echo "$filename"
# Backup network config
cp /etc/config/network "/etc/config/$filename" || exit 1
echo "$config_interface"
echo "$config_peer"
echo "$config_interface" >> /etc/config/network
echo "$config_peer" >> /etc/config/network
# Reload network
#/etc/init.d/network restart && echo "Success" || echo "Failed"
Ok, some updates: due to OpenWrt compatibility I need to avoid uppercase in interfaces names.
Due I am using underscore in interface names, I need /etc/init.d/network restart instead of /etc/init.d/network reload.
You can change code to create instead wg0, wg1, wg2, … interface names, so you’ll simply need /etc/init.d/network reload to correctly update router.
Mmh… after further testing, I discovered I can’t access to my RUT200 from outside, more precisely I can access only from “wg0” (let’s say main wireguard) but “wg0” (backup) is unreachable.
On firewall zones I find a “wireguard” zone with wg0 interface.
I need to manually add wg0 to “wireguard” zone, while this is automatically made using OpenVpn.
I don’t know why…
