Is there any direct ‘4G/5G-replacement’ for the TWCT22 when the 2G/3G is to be shut down (Sweden)?
Unfortunately no
Hello @enilken,
Could you please elaborate a bit on your use case and which features of the TWCT22 are most important for you? This way I can check and suggest the most similar LTE/5G device from the Networks portfolio that would suit your needs.
