I have a small network with a TSW202 (FW: TSW2_R_00.01.05; batch 1) and a TSW114 (batch 28). I would like to power the 114 via PoE from the 202.
PoE is enabled on all ports as per FW defaults, and the 202 is supplied with 48V. However, connecting ethernet to the 114’s first port does not power the device.
Per 202 docs, there is a PoE mode change between batches, but I’m not sure if that is the root cause here.
Are these devices not PoE-compatiable with each other? Thanks.
TSW 202 can only power other devices with PoE but it cannot be powered by it. I am not entirely sure if Teltonika has any switches that can be powered with active PoE.
