More than a week has passed and no replies - some feedback from Teltonika would be welcome. The switch needs to be installed in a remote location and I can’t have the connected PDs rebooting for no reason. At the moment the only solution seems to be to not use switch ports 4 and 8 for POE which I am sure is not correct behaviour.
As stated in the opening post, whenever POE on switch ports 4 and 8 is turned off other switch ports will be reset. In kernel logs the following message is displayed for the affected ports -
Port is not eligible for power due to unknown class
Turning off POE on switch port4 -
debug1: Sending command: logread -f
4370 Tue Nov 10 10:32:54 2026 events.notice CONFIG: User “admin” changed Poe configuration in “network/ports/ports-settings” page
4371 Tue Nov 10 10:32:56 2026 kern.info kernel: [445447.035833] RTL8380 Link change: status: 1, ports 800
4372 Tue Nov 10 10:32:57 2026 kern.info kernel: [445447.041779] rtl83xx-switch switch@1b000000 port4: Link is Down
4373 Tue Nov 10 10:32:57 2026 kern.info kernel: [445447.049037] br0: port 4(port4) entered disabled state
4374 Tue Nov 10 10:32:57 2026 kern.info kernel: [445447.215111] rtl83xx-switch switch@1b000000 port4: Link is Up - 100Mbps/Full - flow control off
4375 Tue Nov 10 10:32:57 2026 kern.info kernel: [445447.225077] br0: port 4(port4) entered blocking state
4376 Tue Nov 10 10:32:57 2026 kern.info kernel: [445447.927743] rtl83xx-switch switch@1b000000 port4: Link is Down
4377 Tue Nov 10 10:32:58 2026 kern.info kernel: [445447.934527] br0: port 4(port4) entered disabled state
4378 Tue Nov 10 10:32:58 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4379 Tue Nov 10 10:32:58 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port4:0 entering blocking state
4380 Tue Nov 10 10:32:58 2026 daemon.notice netifd: Network device ‘port4’ link is down
4381 Tue Nov 10 10:32:58 2026 network.notice Network device ‘port4’ entering blocking STP state
4382 Tue Nov 10 10:32:58 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port4:0 Flushing forwarding database
4383 Tue Nov 10 10:32:59 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4384 Tue Nov 10 10:32:59 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : up
4385 Tue Nov 10 10:32:59 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port4:0 entering learning state
4386 Tue Nov 10 10:32:59 2026 network.notice Network device ‘port4’ entering learning STP state
4387 Tue Nov 10 10:32:59 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
4388 Tue Nov 10 10:33:00 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port4 Couldn’t set kernel bridge state learning
4389 Tue Nov 10 10:33:00 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : up
4390 Tue Nov 10 10:33:00 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4391 Tue Nov 10 10:33:00 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port4:0 entering blocking state
4392 Tue Nov 10 10:33:00 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4393 Tue Nov 10 10:33:01 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4394 Tue Nov 10 10:33:01 2026 network.notice Network device ‘port4’ entering blocking STP state
4395 Tue Nov 10 10:33:01 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port4:0 Flushing forwarding database
4396 Tue Nov 10 10:33:01 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4397 Tue Nov 10 10:33:01 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4398 Tue Nov 10 10:33:02 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4399 Tue Nov 10 10:33:02 2026 daemon.info tswconfig[2296]: set_if_up: Port port4 : down
4400 Tue Nov 10 10:33:02 2026 network.notice Port link state of port port4 changed to DOWN
4401 Tue Nov 10 10:33:08 2026 kern.info kernel: [445458.406171] poe port3: Port is not eligible for power due to unknown class
4402 Tue Nov 10 10:33:08 2026 kern.info kernel: [445458.414415] poe port2: Port is not eligible for power due to unknown class
4403 Tue Nov 10 10:33:08 2026 kern.info kernel: [445458.422808] poe port1: Port is not eligible for power due to unknown class
4404 Tue Nov 10 10:33:08 2026 kern.info kernel: [445458.455971] RTL8380 Link change: status: 1, ports 4000000
4405 Tue Nov 10 10:33:09 2026 kern.info kernel: [445458.545385] RTL8380 Link change: status: 1, ports 200
4406 Tue Nov 10 10:33:09 2026 kern.info kernel: [445458.651048] RTL8380 Link change: status: 1, ports 100
4407 Tue Nov 10 10:33:09 2026 kern.info kernel: [445458.810519] RTL8380 Link change: status: 1, ports 1000000
4408 Tue Nov 10 10:33:09 2026 kern.info kernel: [445458.844159] rtl83xx-switch switch@1b000000 sfp2: Link is Down
4409 Tue Nov 10 10:33:09 2026 kern.info kernel: [445458.850986] br0: port 10(sfp2) entered disabled state
4410 Tue Nov 10 10:33:10 2026 kern.info kernel: [445459.012571] rtl83xx-switch switch@1b000000 port2: Link is Down
4411 Tue Nov 10 10:33:10 2026 kern.info kernel: [445459.019494] br0: port 2(port2) entered disabled state
4412 Tue Nov 10 10:33:10 2026 kern.info kernel: [445459.127065] rtl83xx-switch switch@1b000000 port1: Link is Down
4413 Tue Nov 10 10:33:10 2026 kern.info kernel: [445459.133856] br0: port 1(port1) entered disabled state
4414 Tue Nov 10 10:33:10 2026 kern.info kernel: [445459.144031] rtl83xx-switch switch@1b000000 sfp1: Link is Down
4415 Tue Nov 10 10:33:11 2026 kern.info kernel: [445459.332052] br0: port 9(sfp1) entered disabled state
4416 Tue Nov 10 10:33:11 2026 daemon.notice netifd: Network device ‘sfp2’ link is down
4417 Tue Nov 10 10:33:11 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4418 Tue Nov 10 10:33:11 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp2:0 entering blocking state
4419 Tue Nov 10 10:33:11 2026 daemon.notice netifd: Network device ‘port2’ link is down
4420 Tue Nov 10 10:33:11 2026 daemon.notice netifd: Network device ‘port1’ link is down
4421 Tue Nov 10 10:33:12 2026 daemon.notice netifd: Network device ‘sfp1’ link is down
4422 Tue Nov 10 10:33:12 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4423 Tue Nov 10 10:33:12 2026 network.notice Network device ‘sfp2’ entering blocking STP state
4424 Tue Nov 10 10:33:12 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:sfp2:0 Flushing forwarding database
4425 Tue Nov 10 10:33:12 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4426 Tue Nov 10 10:33:13 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4427 Tue Nov 10 10:33:13 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4428 Tue Nov 10 10:33:13 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering blocking state
4429 Tue Nov 10 10:33:13 2026 network.notice Network device ‘port2’ entering blocking STP state
4430 Tue Nov 10 10:33:13 2026 kern.info kernel: [445463.847841] RTL8380 Link change: status: 1, ports 1000000
4431 Tue Nov 10 10:33:14 2026 network.notice Network device ‘port1’ entering blocking STP state
4432 Tue Nov 10 10:33:14 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port2:0 Flushing forwarding database
4433 Tue Nov 10 10:33:14 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4434 Tue Nov 10 10:33:14 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4435 Tue Nov 10 10:33:14 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4436 Tue Nov 10 10:33:15 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering blocking state
4437 Tue Nov 10 10:33:15 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port1:0 Flushing forwarding database
4438 Tue Nov 10 10:33:15 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4439 Tue Nov 10 10:33:15 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4440 Tue Nov 10 10:33:15 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : down
4441 Tue Nov 10 10:33:16 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp1:0 entering blocking state
4442 Tue Nov 10 10:33:16 2026 daemon.notice netifd: Network device ‘sfp1’ link is up
4443 Tue Nov 10 10:33:16 2026 daemon.notice netifd: Interface ‘dhcp’ has lost the connection
4444 Tue Nov 10 10:33:16 2026 user.info : Starting database size optimization…
4445 Tue Nov 10 10:33:17 2026 network.notice Network device ‘sfp1’ entering blocking STP state
4446 Tue Nov 10 10:33:17 2026 kern.info kernel: [445464.493676] rtl83xx-switch switch@1b000000 sfp1: Link is Up - 1Gbps/Full - flow control off
4447 Tue Nov 10 10:33:17 2026 kern.info kernel: [445464.503377] br0: port 9(sfp1) entered blocking state
4448 Tue Nov 10 10:33:17 2026 network.notice Network device ‘sfp1’ entering learning STP state
4449 Tue Nov 10 10:33:17 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:sfp1:0 Flushing forwarding database
4450 Tue Nov 10 10:33:18 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : down
4451 Tue Nov 10 10:33:18 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : down
4452 Tue Nov 10 10:33:18 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4453 Tue Nov 10 10:33:18 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4454 Tue Nov 10 10:33:18 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4455 Tue Nov 10 10:33:18 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : up
4456 Tue Nov 10 10:33:19 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp1:0 entering learning state
4457 Tue Nov 10 10:33:19 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : up
4458 Tue Nov 10 10:33:19 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : up
4459 Tue Nov 10 10:33:19 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : up
4460 Tue Nov 10 10:33:19 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : up
4461 Tue Nov 10 10:33:20 2026 network.notice Port link state of port port1 changed to DOWN
4462 Tue Nov 10 10:33:20 2026 kern.info kernel: [445468.057026] br0: port 9(sfp1) entered learning state
4463 Tue Nov 10 10:33:20 2026 kern.info kernel: [445470.087544] RTL8380 Link change: status: 1, ports 4000000
4464 Tue Nov 10 10:33:20 2026 kern.info kernel: [445470.487183] rtl83xx-switch switch@1b000000 sfp2: Link is Up - 100Mbps/Full - flow control off
4465 Tue Nov 10 10:33:20 2026 kern.info kernel: [445470.497076] br0: port 10(sfp2) entered blocking state
4466 Tue Nov 10 10:33:20 2026 network.notice Port link state of port port2 changed to DOWN
4467 Tue Nov 10 10:33:21 2026 daemon.notice netifd: Network device ‘sfp2’ link is up
4468 Tue Nov 10 10:33:21 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4469 Tue Nov 10 10:33:21 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4470 Tue Nov 10 10:33:21 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4471 Tue Nov 10 10:33:22 2026 kern.info kernel: [445472.230056] RTL8380 Link change: status: 1, ports 200
4472 Tue Nov 10 10:33:22 2026 kern.info kernel: [445472.251982] rtl83xx-switch switch@1b000000 port2: Link is Up - 100Mbps/Full - flow control off
4473 Tue Nov 10 10:33:22 2026 kern.info kernel: [445472.261962] br0: port 2(port2) entered blocking state
4474 Tue Nov 10 10:33:22 2026 daemon.notice netifd: Network device ‘port2’ link is up
4475 Tue Nov 10 10:33:22 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4476 Tue Nov 10 10:33:23 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4477 Tue Nov 10 10:33:23 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp1:0 entering forwarding state
4478 Tue Nov 10 10:33:23 2026 network.notice Network device ‘sfp1’ entering forwarding STP state
4479 Tue Nov 10 10:33:23 2026 kern.info kernel: [445473.771706] br0: port 9(sfp1) entered forwarding state
4480 Tue Nov 10 10:33:23 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4481 Tue Nov 10 10:33:23 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp1 : up
4482 Tue Nov 10 10:33:24 2026 network.notice Port link state of port port2 (100 baseT) changed to UP
4483 Tue Nov 10 10:33:24 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering learning state
4484 Tue Nov 10 10:33:24 2026 network.notice Network device ‘port2’ entering learning STP state
4485 Tue Nov 10 10:33:24 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering forwarding state
4486 Tue Nov 10 10:33:25 2026 kern.info kernel: [445475.126317] br0: port 2(port2) entered learning state
4487 Tue Nov 10 10:33:25 2026 network.notice Network device ‘port2’ entering forwarding STP state
4488 Tue Nov 10 10:33:25 2026 kern.info kernel: [445475.643912] br0: port 2(port2) entered forwarding state
4489 Tue Nov 10 10:33:25 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp2:0 entering learning state
4490 Tue Nov 10 10:33:25 2026 network.notice Network device ‘sfp2’ entering learning STP state
4491 Tue Nov 10 10:33:26 2026 kern.info kernel: [445476.205428] br0: port 10(sfp2) entered learning state
4492 Tue Nov 10 10:33:26 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp2:0 entering forwarding state
4493 Tue Nov 10 10:33:26 2026 network.notice Network device ‘sfp2’ entering forwarding STP state
4494 Tue Nov 10 10:33:26 2026 kern.info kernel: [445476.759926] br0: port 10(sfp2) entered forwarding state
4495 Tue Nov 10 10:33:26 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4496 Tue Nov 10 10:33:26 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4497 Tue Nov 10 10:33:27 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4498 Tue Nov 10 10:33:27 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4499 Tue Nov 10 10:33:27 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4500 Tue Nov 10 10:33:27 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4501 Tue Nov 10 10:33:27 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4502 Tue Nov 10 10:33:28 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering blocking state
4503 Tue Nov 10 10:33:28 2026 daemon.notice netifd: Network device ‘port2’ link is down
4504 Tue Nov 10 10:33:28 2026 daemon.notice netifd: Network device ‘port1’ link is up
4505 Tue Nov 10 10:33:28 2026 kern.info kernel: [445477.240226] RTL8380 Link change: status: 1, ports 200
4506 Tue Nov 10 10:33:28 2026 kern.info kernel: [445477.246326] rtl83xx-switch switch@1b000000 port2: Link is Down
4507 Tue Nov 10 10:33:29 2026 kern.info kernel: [445477.253038] rtl83xx-switch switch@1b000000 port2: Link is Up - 100Mbps/Full - flow control off
4508 Tue Nov 10 10:33:29 2026 kern.info kernel: [445477.285076] RTL8380 Link change: status: 1, ports 100
4509 Tue Nov 10 10:33:29 2026 kern.info kernel: [445477.717326] rtl83xx-switch switch@1b000000 port2: Link is Down
4510 Tue Nov 10 10:33:29 2026 kern.info kernel: [445477.724185] br0: port 2(port2) entered disabled state
4511 Tue Nov 10 10:33:29 2026 kern.warn kernel: [445478.089953] Realtek RTL8218B (internal) mdio-bus:08: Downshift occurred from negotiated speed 1Gbps to actual speed 100Mbps, check cabling!
4512 Tue Nov 10 10:33:30 2026 kern.info kernel: [445478.380965] rtl83xx-switch switch@1b000000 port1: Link is Up - 100Mbps/Full - flow control off
4513 Tue Nov 10 10:33:30 2026 kern.info kernel: [445478.390956] br0: port 1(port1) entered blocking state
4514 Tue Nov 10 10:33:30 2026 network.notice Network device ‘port2’ entering blocking STP state
4515 Tue Nov 10 10:33:30 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port2:0 Flushing forwarding database
4516 Tue Nov 10 10:33:30 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4517 Tue Nov 10 10:33:31 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4518 Tue Nov 10 10:33:31 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4519 Tue Nov 10 10:33:31 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4520 Tue Nov 10 10:33:31 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4521 Tue Nov 10 10:33:31 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4522 Tue Nov 10 10:33:32 2026 daemon.notice netifd: Network device ‘port2’ link is up
4523 Tue Nov 10 10:33:32 2026 network.notice Port link state of port port1 (100 baseT) changed to UP
4524 Tue Nov 10 10:33:32 2026 kern.info kernel: [445481.498703] RTL8380 Link change: status: 1, ports 200
4525 Tue Nov 10 10:33:32 2026 kern.info kernel: [445481.928784] rtl83xx-switch switch@1b000000 port2: Link is Up - 100Mbps/Full - flow control off
4526 Tue Nov 10 10:33:32 2026 kern.info kernel: [445481.938760] br0: port 2(port2) entered blocking state
4527 Tue Nov 10 10:33:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4528 Tue Nov 10 10:33:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4529 Tue Nov 10 10:33:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4530 Tue Nov 10 10:33:34 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering learning state
4531 Tue Nov 10 10:33:35 2026 network.notice Network device ‘port1’ entering learning STP state
4532 Tue Nov 10 10:33:35 2026 kern.info kernel: [445485.520236] br0: port 1(port1) entered learning state
4533 Tue Nov 10 10:33:35 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering forwarding state
4534 Tue Nov 10 10:33:35 2026 network.notice Network device ‘port1’ entering forwarding STP state
4535 Tue Nov 10 10:33:35 2026 kern.info kernel: [445486.135826] br0: port 1(port1) entered forwarding state
4536 Tue Nov 10 10:33:36 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4537 Tue Nov 10 10:33:36 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4538 Tue Nov 10 10:33:36 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering learning state
4539 Tue Nov 10 10:33:36 2026 network.notice Network device ‘port2’ entering learning STP state
4540 Tue Nov 10 10:33:36 2026 kern.info kernel: [445487.166075] br0: port 2(port2) entered learning state
4541 Tue Nov 10 10:33:37 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering forwarding state
4542 Tue Nov 10 10:33:37 2026 network.notice Network device ‘port2’ entering forwarding STP state
4543 Tue Nov 10 10:33:37 2026 kern.info kernel: [445487.718099] br0: port 2(port2) entered forwarding state
4544 Tue Nov 10 10:33:37 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4545 Tue Nov 10 10:33:37 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4546 Tue Nov 10 10:33:38 2026 user.info : Finished database optimization
4547 Tue Nov 10 10:33:42 2026 kern.info kernel: [445492.767728] RTL8380 Link change: status: 1, ports 4000000
4548 Tue Nov 10 10:33:42 2026 kern.info kernel: [445492.774172] rtl83xx-switch switch@1b000000 sfp2: Link is Down
4549 Tue Nov 10 10:33:42 2026 kern.info kernel: [445492.781024] br0: port 10(sfp2) entered disabled state
4550 Tue Nov 10 10:33:43 2026 daemon.notice netifd: Network device ‘sfp2’ link is down
4551 Tue Nov 10 10:33:43 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4552 Tue Nov 10 10:33:43 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp2:0 entering blocking state
4553 Tue Nov 10 10:33:43 2026 network.notice Network device ‘sfp2’ entering blocking STP state
4554 Tue Nov 10 10:33:43 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:sfp2:0 Flushing forwarding database
4555 Tue Nov 10 10:33:44 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4556 Tue Nov 10 10:33:44 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4557 Tue Nov 10 10:33:44 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : down
4558 Tue Nov 10 10:33:44 2026 network.notice Port link state of port sfp2 changed to DOWN
4559 Tue Nov 10 10:33:47 2026 kern.info kernel: [445498.168615] RTL8380 Link change: status: 1, ports 4000000
4560 Tue Nov 10 10:33:48 2026 kern.info kernel: [445498.196545] rtl83xx-switch switch@1b000000 sfp2: Link is Up - 100Mbps/Full - flow control off
4561 Tue Nov 10 10:33:48 2026 kern.info kernel: [445498.206448] br0: port 10(sfp2) entered blocking state
4562 Tue Nov 10 10:33:48 2026 daemon.notice netifd: Network device ‘sfp2’ link is up
4563 Tue Nov 10 10:33:48 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4564 Tue Nov 10 10:33:48 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4565 Tue Nov 10 10:33:49 2026 network.notice Port link state of port sfp2 (100 baseT) changed to UP
4566 Tue Nov 10 10:33:49 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4567 Tue Nov 10 10:33:50 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp2:0 entering learning state
4568 Tue Nov 10 10:33:51 2026 network.notice Network device ‘sfp2’ entering learning STP state
4569 Tue Nov 10 10:33:51 2026 kern.info kernel: [445501.437582] br0: port 10(sfp2) entered learning state
4570 Tue Nov 10 10:33:51 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:sfp2:0 entering forwarding state
4571 Tue Nov 10 10:33:51 2026 network.notice Network device ‘sfp2’ entering forwarding STP state
4572 Tue Nov 10 10:33:51 2026 kern.info kernel: [445502.047187] br0: port 10(sfp2) entered forwarding state
4573 Tue Nov 10 10:33:52 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4574 Tue Nov 10 10:33:52 2026 daemon.info tswconfig[2296]: set_if_up: Port sfp2 : up
4575 Tue Nov 10 10:33:53 2026 kern.info kernel: [445503.352772] RTL8380 Link change: status: 1, ports 200
4576 Tue Nov 10 10:33:53 2026 kern.info kernel: [445503.362467] rtl83xx-switch switch@1b000000 port2: Link is Down
4577 Tue Nov 10 10:33:53 2026 kern.info kernel: [445503.369441] br0: port 2(port2) entered disabled state
4578 Tue Nov 10 10:33:53 2026 kern.info kernel: [445503.522096] rtl83xx-switch switch@1b000000 port2: Link is Up - 100Mbps/Full - flow control off
4579 Tue Nov 10 10:33:53 2026 kern.info kernel: [445503.532126] br0: port 2(port2) entered blocking state
4580 Tue Nov 10 10:33:54 2026 kern.info kernel: [445503.862298] rtl83xx-switch switch@1b000000 port2: Link is Down
4581 Tue Nov 10 10:33:54 2026 kern.info kernel: [445503.869273] br0: port 2(port2) entered disabled state
4582 Tue Nov 10 10:33:54 2026 daemon.notice netifd: Network device ‘port2’ link is down
4583 Tue Nov 10 10:33:54 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4584 Tue Nov 10 10:33:54 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering blocking state
4585 Tue Nov 10 10:33:55 2026 daemon.notice netifd: Network device ‘port2’ link is up
4586 Tue Nov 10 10:33:55 2026 daemon.notice netifd: Network device ‘port2’ link is down
4587 Tue Nov 10 10:33:55 2026 network.notice Network device ‘port2’ entering blocking STP state
4588 Tue Nov 10 10:33:55 2026 kern.info kernel: [445504.943730] RTL8380 Link change: status: 1, ports 200
4589 Tue Nov 10 10:33:55 2026 kern.info kernel: [445505.928759] rtl83xx-switch switch@1b000000 port2: Link is Up - 100Mbps/Full - flow control off
4590 Tue Nov 10 10:33:56 2026 kern.info kernel: [445505.938756] br0: port 2(port2) entered blocking state
4591 Tue Nov 10 10:33:56 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port2:0 Flushing forwarding database
4592 Tue Nov 10 10:33:56 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4593 Tue Nov 10 10:33:56 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4594 Tue Nov 10 10:33:56 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4595 Tue Nov 10 10:33:57 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering learning state
4596 Tue Nov 10 10:33:57 2026 daemon.notice netifd: Network device ‘port2’ link is up
4597 Tue Nov 10 10:33:57 2026 network.notice Network device ‘port2’ entering learning STP state
4598 Tue Nov 10 10:33:57 2026 kern.info kernel: [445507.635767] RTL8380 Link change: status: 1, ports 100
4599 Tue Nov 10 10:33:57 2026 kern.info kernel: [445507.641674] rtl83xx-switch switch@1b000000 port1: Link is Down
4600 Tue Nov 10 10:33:58 2026 kern.info kernel: [445507.648586] br0: port 1(port1) entered disabled state
4601 Tue Nov 10 10:33:58 2026 kern.info kernel: [445507.739273] rtl83xx-switch switch@1b000000 port1: Link is Up - 100Mbps/Full - flow control off
4602 Tue Nov 10 10:33:58 2026 kern.info kernel: [445507.749264] br0: port 1(port1) entered blocking state
4603 Tue Nov 10 10:33:58 2026 kern.info kernel: [445507.805873] br0: port 2(port2) entered learning state
4604 Tue Nov 10 10:33:58 2026 kern.info kernel: [445508.254285] rtl83xx-switch switch@1b000000 port1: Link is Down
4605 Tue Nov 10 10:33:59 2026 kern.info kernel: [445508.261234] br0: port 1(port1) entered disabled state
4606 Tue Nov 10 10:33:59 2026 daemon.notice netifd: Network device ‘port1’ link is down
4607 Tue Nov 10 10:33:59 2026 daemon.notice netifd: Network device ‘port1’ link is up
4608 Tue Nov 10 10:33:59 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4609 Tue Nov 10 10:33:59 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4610 Tue Nov 10 10:33:59 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering blocking state
4611 Tue Nov 10 10:34:00 2026 daemon.notice netifd: Network device ‘port1’ link is down
4612 Tue Nov 10 10:34:00 2026 network.notice Network device ‘port2’ entering blocking STP state
4613 Tue Nov 10 10:34:00 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port2:0 Flushing forwarding database
4614 Tue Nov 10 10:34:00 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4615 Tue Nov 10 10:34:00 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4616 Tue Nov 10 10:34:01 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
4617 Tue Nov 10 10:34:01 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4618 Tue Nov 10 10:34:01 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4619 Tue Nov 10 10:34:01 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4620 Tue Nov 10 10:34:01 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering blocking state
4621 Tue Nov 10 10:34:02 2026 network.notice Network device ‘port1’ entering blocking STP state
4622 Tue Nov 10 10:34:02 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port1:0 Flushing forwarding database
4623 Tue Nov 10 10:34:02 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4624 Tue Nov 10 10:34:02 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4625 Tue Nov 10 10:34:03 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4626 Tue Nov 10 10:34:03 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering learning state
4627 Tue Nov 10 10:34:03 2026 network.notice Network device ‘port1’ entering learning STP state
4628 Tue Nov 10 10:34:03 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
4629 Tue Nov 10 10:34:03 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port1 Couldn’t set kernel bridge state learning
4630 Tue Nov 10 10:34:04 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4631 Tue Nov 10 10:34:04 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4632 Tue Nov 10 10:34:04 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4633 Tue Nov 10 10:34:04 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering blocking state
4634 Tue Nov 10 10:34:04 2026 network.notice Network device ‘port1’ entering blocking STP state
4635 Tue Nov 10 10:34:05 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port1:0 Flushing forwarding database
4636 Tue Nov 10 10:34:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4637 Tue Nov 10 10:34:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4638 Tue Nov 10 10:34:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4639 Tue Nov 10 10:34:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4640 Tue Nov 10 10:34:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : down
4641 Tue Nov 10 10:34:06 2026 network.notice Port link state of port port1 changed to DOWN
4642 Tue Nov 10 10:34:07 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering learning state
4643 Tue Nov 10 10:34:07 2026 network.notice Network device ‘port2’ entering learning STP state
4644 Tue Nov 10 10:34:07 2026 kern.info kernel: [445517.878279] br0: port 2(port2) entered learning state
4645 Tue Nov 10 10:34:07 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4646 Tue Nov 10 10:34:08 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering forwarding state
4647 Tue Nov 10 10:34:08 2026 network.notice Network device ‘port2’ entering forwarding STP state
4648 Tue Nov 10 10:34:08 2026 kern.info kernel: [445518.874762] br0: port 2(port2) entered forwarding state
4649 Tue Nov 10 10:34:08 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
4650 Tue Nov 10 10:34:09 2026 kern.info kernel: [445519.501120] RTL8380 Link change: status: 1, ports 100
4651 Tue Nov 10 10:34:09 2026 kern.info kernel: [445519.694613] rtl83xx-switch switch@1b000000 port1: Link is Up - 100Mbps/Full - flow control off
4652 Tue Nov 10 10:34:09 2026 kern.info kernel: [445519.704603] br0: port 1(port1) entered blocking state
4653 Tue Nov 10 10:34:09 2026 daemon.notice netifd: Network device ‘port1’ link is up
4654 Tue Nov 10 10:34:10 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4655 Tue Nov 10 10:34:10 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4656 Tue Nov 10 10:34:10 2026 network.notice Port link state of port port1 (100 baseT) changed to UP
4657 Tue Nov 10 10:34:12 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering learning state
4658 Tue Nov 10 10:34:12 2026 network.notice Network device ‘port1’ entering learning STP state
4659 Tue Nov 10 10:34:12 2026 kern.info kernel: [445522.970384] br0: port 1(port1) entered learning state
4660 Tue Nov 10 10:34:12 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port1:0 entering forwarding state
4661 Tue Nov 10 10:34:13 2026 network.notice Network device ‘port1’ entering forwarding STP state
4662 Tue Nov 10 10:34:13 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4663 Tue Nov 10 10:34:13 2026 daemon.info tswconfig[2296]: set_if_up: Port port1 : up
4664 Tue Nov 10 10:34:13 2026 kern.info kernel: [445523.541568] br0: port 1(port1) entered forwarding state
4665 Tue Nov 10 10:34:16 2026 daemon.notice netifd: dhcp (2938): udhcpc: broadcasting select for 192.168.1.106, server 192.168.1.3
4666 Tue Nov 10 10:34:17 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4667 Tue Nov 10 10:34:17 2026 daemon.notice netifd: Interface ‘dhcp’ is now up
4668 Tue Nov 10 10:34:20 2026 user.notice nlbwmon: Reloading nlbwmon due to ifup of dhcp (br0.1)
4669 Tue Nov 10 10:34:21 2026 user.notice udhcpc: Error: no option
4670 Tue Nov 10 10:36:25 2026 authpriv.info dropbear[19513]: Exit (root) from <192.168.2.8:43404>: Keepalive timeout
Turning off POE on switch port8 -
4674 Tue Nov 10 10:37:59 2026 events.notice CONFIG: User “admin” changed Poe configuration in “network/ports/ports-settings” page
4675 Tue Nov 10 10:38:00 2026 kern.info kernel: [445751.083548] RTL8380 Link change: status: 1, ports 8000
4676 Tue Nov 10 10:38:01 2026 kern.info kernel: [445751.107291] rtl83xx-switch switch@1b000000 port8: Link is Down
4677 Tue Nov 10 10:38:01 2026 kern.info kernel: [445751.114090] br0: port 8(port8) entered disabled state
4678 Tue Nov 10 10:38:01 2026 kern.info kernel: [445751.129728] rtl83xx-switch switch@1b000000 port8: Link is Up - 100Mbps/Full - flow control off
4679 Tue Nov 10 10:38:01 2026 kern.info kernel: [445751.315032] br0: port 8(port8) entered blocking state
4680 Tue Nov 10 10:38:01 2026 kern.info kernel: [445751.389032] rtl83xx-switch switch@1b000000 port8: Link is Down
4681 Tue Nov 10 10:38:02 2026 kern.info kernel: [445751.406359] br0: port 8(port8) entered disabled state
4682 Tue Nov 10 10:38:02 2026 daemon.notice netifd: Network device ‘port8’ link is down
4683 Tue Nov 10 10:38:02 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4684 Tue Nov 10 10:38:02 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port8:0 entering blocking state
4685 Tue Nov 10 10:38:02 2026 daemon.notice netifd: Network device ‘port8’ link is up
4686 Tue Nov 10 10:38:03 2026 daemon.notice netifd: Network device ‘port8’ link is down
4687 Tue Nov 10 10:38:03 2026 network.notice Network device ‘port8’ entering blocking STP state
4688 Tue Nov 10 10:38:03 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4689 Tue Nov 10 10:38:03 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4690 Tue Nov 10 10:38:03 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port8:0 Flushing forwarding database
4691 Tue Nov 10 10:38:04 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4692 Tue Nov 10 10:38:04 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4693 Tue Nov 10 10:38:04 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : up
4694 Tue Nov 10 10:38:04 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port8:0 entering learning state
4695 Tue Nov 10 10:38:05 2026 network.notice Network device ‘port8’ entering learning STP state
4696 Tue Nov 10 10:38:05 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
4697 Tue Nov 10 10:38:05 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port8 Couldn’t set kernel bridge state learning
4698 Tue Nov 10 10:38:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : up
4699 Tue Nov 10 10:38:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4700 Tue Nov 10 10:38:06 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port8:0 entering blocking state
4701 Tue Nov 10 10:38:06 2026 network.notice Network device ‘port8’ entering blocking STP state
4702 Tue Nov 10 10:38:06 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port8:0 Flushing forwarding database
4703 Tue Nov 10 10:38:06 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4704 Tue Nov 10 10:38:06 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4705 Tue Nov 10 10:38:07 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4706 Tue Nov 10 10:38:07 2026 daemon.info tswconfig[2296]: set_if_up: Port port8 : down
4707 Tue Nov 10 10:38:07 2026 network.notice Port link state of port port8 changed to DOWN
4708 Tue Nov 10 10:38:07 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4709 Tue Nov 10 10:38:07 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4710 Tue Nov 10 10:38:08 2026 kern.info kernel: [445758.727230] poe port5: Port is not eligible for power due to unknown class
4711 Tue Nov 10 10:38:08 2026 kern.info kernel: [445758.886546] RTL8380 Link change: status: 1, ports 1000
4712 Tue Nov 10 10:38:09 2026 kern.info kernel: [445758.959267] rtl83xx-switch switch@1b000000 port5: Link is Down
4713 Tue Nov 10 10:38:09 2026 kern.info kernel: [445758.966216] br0: port 5(port5) entered disabled state
4714 Tue Nov 10 10:38:09 2026 kern.info kernel: [445759.101983] rtl83xx-switch switch@1b000000 port5: Link is Up - 100Mbps/Full - flow control off
4715 Tue Nov 10 10:38:09 2026 kern.info kernel: [445759.111984] br0: port 5(port5) entered blocking state
4716 Tue Nov 10 10:38:09 2026 kern.info kernel: [445759.386704] poe port7: Port is not eligible for power due to unknown class
4717 Tue Nov 10 10:38:10 2026 kern.info kernel: [445759.395125] poe port6: Port is not eligible for power due to unknown class
4718 Tue Nov 10 10:38:10 2026 kern.info kernel: [445759.563536] RTL8380 Link change: status: 1, ports 2000
4719 Tue Nov 10 10:38:10 2026 kern.info kernel: [445759.595565] rtl83xx-switch switch@1b000000 port6: Link is Down
4720 Tue Nov 10 10:38:10 2026 kern.info kernel: [445759.602361] br0: port 6(port6) entered disabled state
4721 Tue Nov 10 10:38:11 2026 kern.info kernel: [445759.612671] rtl83xx-switch switch@1b000000 port6: Link is Up - 100Mbps/Full - flow control off
4722 Tue Nov 10 10:38:11 2026 kern.info kernel: [445759.822221] br0: port 6(port6) entered blocking state
4723 Tue Nov 10 10:38:11 2026 kern.info kernel: [445759.936002] rtl83xx-switch switch@1b000000 port6: Link is Down
4724 Tue Nov 10 10:38:11 2026 kern.info kernel: [445759.946148] br0: port 6(port6) entered disabled state
4725 Tue Nov 10 10:38:11 2026 kern.info kernel: [445760.219021] rtl83xx-switch switch@1b000000 port5: Link is Down
4726 Tue Nov 10 10:38:12 2026 kern.info kernel: [445760.225964] br0: port 5(port5) entered disabled state
4727 Tue Nov 10 10:38:12 2026 daemon.notice netifd: Network device ‘port5’ link is down
4728 Tue Nov 10 10:38:12 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4729 Tue Nov 10 10:38:12 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering blocking state
4730 Tue Nov 10 10:38:12 2026 daemon.notice netifd: Network device ‘port5’ link is up
4731 Tue Nov 10 10:38:13 2026 daemon.notice netifd: Network device ‘port6’ link is down
4732 Tue Nov 10 10:38:13 2026 daemon.notice netifd: Network device ‘port6’ link is up
4733 Tue Nov 10 10:38:13 2026 daemon.notice netifd: Network device ‘port6’ link is down
4734 Tue Nov 10 10:38:13 2026 daemon.notice netifd: Network device ‘port5’ link is down
4735 Tue Nov 10 10:38:13 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4736 Tue Nov 10 10:38:14 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4737 Tue Nov 10 10:38:14 2026 network.notice Network device ‘port5’ entering blocking STP state
4738 Tue Nov 10 10:38:14 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port5:0 Flushing forwarding database
4739 Tue Nov 10 10:38:14 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4740 Tue Nov 10 10:38:14 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4741 Tue Nov 10 10:38:15 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4742 Tue Nov 10 10:38:15 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering learning state
4743 Tue Nov 10 10:38:15 2026 network.notice Network device ‘port5’ entering learning STP state
4744 Tue Nov 10 10:38:15 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
4745 Tue Nov 10 10:38:15 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port5 Couldn’t set kernel bridge state learning
4746 Tue Nov 10 10:38:16 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4747 Tue Nov 10 10:38:16 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4748 Tue Nov 10 10:38:16 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering blocking state
4749 Tue Nov 10 10:38:16 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4750 Tue Nov 10 10:38:16 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4751 Tue Nov 10 10:38:17 2026 network.notice Network device ‘port6’ entering blocking STP state
4752 Tue Nov 10 10:38:17 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port6:0 Flushing forwarding database
4753 Tue Nov 10 10:38:17 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4754 Tue Nov 10 10:38:17 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4755 Tue Nov 10 10:38:17 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4756 Tue Nov 10 10:38:18 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering learning state
4757 Tue Nov 10 10:38:18 2026 network.notice Network device ‘port6’ entering learning STP state
4758 Tue Nov 10 10:38:18 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
4759 Tue Nov 10 10:38:18 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port6 Couldn’t set kernel bridge state learning
4760 Tue Nov 10 10:38:18 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4761 Tue Nov 10 10:38:19 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4762 Tue Nov 10 10:38:19 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering blocking state
4763 Tue Nov 10 10:38:19 2026 daemon.notice netifd: Network device ‘port5’ link is up
4764 Tue Nov 10 10:38:19 2026 network.notice Network device ‘port6’ entering blocking STP state
4765 Tue Nov 10 10:38:19 2026 kern.info kernel: [445768.940173] RTL8380 Link change: status: 1, ports 1000
4766 Tue Nov 10 10:38:20 2026 kern.info kernel: [445769.452585] rtl83xx-switch switch@1b000000 port5: Link is Up - 100Mbps/Full - flow control off
4767 Tue Nov 10 10:38:20 2026 kern.info kernel: [445769.462580] br0: port 5(port5) entered blocking state
4768 Tue Nov 10 10:38:20 2026 network.notice Network device ‘port5’ entering blocking STP state
4769 Tue Nov 10 10:38:20 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port6:0 Flushing forwarding database
4770 Tue Nov 10 10:38:20 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4771 Tue Nov 10 10:38:21 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4772 Tue Nov 10 10:38:21 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4773 Tue Nov 10 10:38:21 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering blocking state
4774 Tue Nov 10 10:38:21 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port5:0 Flushing forwarding database
4775 Tue Nov 10 10:38:21 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4776 Tue Nov 10 10:38:22 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4777 Tue Nov 10 10:38:22 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4778 Tue Nov 10 10:38:22 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4779 Tue Nov 10 10:38:22 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4780 Tue Nov 10 10:38:22 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4781 Tue Nov 10 10:38:23 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4782 Tue Nov 10 10:38:23 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4783 Tue Nov 10 10:38:23 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4784 Tue Nov 10 10:38:23 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4785 Tue Nov 10 10:38:23 2026 daemon.notice netifd: Network device ‘port6’ link is up
4786 Tue Nov 10 10:38:23 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4787 Tue Nov 10 10:38:24 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4788 Tue Nov 10 10:38:24 2026 network.notice Port link state of port port6 changed to DOWN
4789 Tue Nov 10 10:38:24 2026 kern.info kernel: [445771.527884] RTL8380 Link change: status: 1, ports 2000
4790 Tue Nov 10 10:38:24 2026 kern.info kernel: [445772.426752] rtl83xx-switch switch@1b000000 port6: Link is Up - 100Mbps/Full - flow control off
4791 Tue Nov 10 10:38:24 2026 kern.info kernel: [445772.436774] br0: port 6(port6) entered blocking state
4792 Tue Nov 10 10:38:25 2026 network.notice Port link state of port port6 (100 baseT) changed to UP
4793 Tue Nov 10 10:38:25 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4794 Tue Nov 10 10:38:25 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4795 Tue Nov 10 10:38:26 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering learning state
4796 Tue Nov 10 10:38:26 2026 network.notice Network device ‘port5’ entering learning STP state
4797 Tue Nov 10 10:38:27 2026 kern.info kernel: [445777.162382] br0: port 5(port5) entered learning state
4798 Tue Nov 10 10:38:27 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering forwarding state
4799 Tue Nov 10 10:38:27 2026 network.notice Network device ‘port5’ entering forwarding STP state
4800 Tue Nov 10 10:38:27 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4801 Tue Nov 10 10:38:27 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4802 Tue Nov 10 10:38:27 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering learning state
4803 Tue Nov 10 10:38:28 2026 kern.info kernel: [445777.715470] br0: port 5(port5) entered forwarding state
4804 Tue Nov 10 10:38:28 2026 network.notice Network device ‘port6’ entering learning STP state
4805 Tue Nov 10 10:38:28 2026 kern.info kernel: [445778.483040] RTL8380 Link change: status: 1, ports 1000
4806 Tue Nov 10 10:38:28 2026 kern.info kernel: [445778.489225] rtl83xx-switch switch@1b000000 port5: Link is Down
4807 Tue Nov 10 10:38:28 2026 kern.info kernel: [445778.496136] br0: port 5(port5) entered disabled state
4808 Tue Nov 10 10:38:29 2026 kern.info kernel: [445778.596032] rtl83xx-switch switch@1b000000 port5: Link is Up - 100Mbps/Full - flow control off
4809 Tue Nov 10 10:38:29 2026 kern.info kernel: [445778.606010] br0: port 5(port5) entered blocking state
4810 Tue Nov 10 10:38:29 2026 kern.info kernel: [445778.688154] br0: port 6(port6) entered learning state
4811 Tue Nov 10 10:38:29 2026 kern.info kernel: [445778.890903] rtl83xx-switch switch@1b000000 port5: Link is Down
4812 Tue Nov 10 10:38:29 2026 kern.info kernel: [445778.897826] br0: port 5(port5) entered disabled state
4813 Tue Nov 10 10:38:30 2026 daemon.notice netifd: Network device ‘port5’ link is down
4814 Tue Nov 10 10:38:30 2026 daemon.notice netifd: Network device ‘port5’ link is up
4815 Tue Nov 10 10:38:30 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering forwarding state
4816 Tue Nov 10 10:38:30 2026 daemon.notice netifd: Network device ‘port5’ link is down
4817 Tue Nov 10 10:38:30 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4818 Tue Nov 10 10:38:31 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4819 Tue Nov 10 10:38:31 2026 network.notice Network device ‘port6’ entering forwarding STP state
4820 Tue Nov 10 10:38:31 2026 kern.info kernel: [445781.699538] br0: port 6(port6) entered forwarding state
4821 Tue Nov 10 10:38:31 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4822 Tue Nov 10 10:38:31 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering blocking state
4823 Tue Nov 10 10:38:32 2026 network.notice Network device ‘port5’ entering blocking STP state
4824 Tue Nov 10 10:38:32 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port5:0 Flushing forwarding database
4825 Tue Nov 10 10:38:32 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4826 Tue Nov 10 10:38:32 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4827 Tue Nov 10 10:38:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4828 Tue Nov 10 10:38:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4829 Tue Nov 10 10:38:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4830 Tue Nov 10 10:38:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4831 Tue Nov 10 10:38:33 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4832 Tue Nov 10 10:38:34 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4833 Tue Nov 10 10:38:34 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4834 Tue Nov 10 10:38:34 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
4835 Tue Nov 10 10:38:34 2026 user.info : Starting database size optimization…
4836 Tue Nov 10 10:38:34 2026 network.notice Port link state of port port5 changed to DOWN
4837 Tue Nov 10 10:38:35 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4838 Tue Nov 10 10:38:35 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4839 Tue Nov 10 10:38:37 2026 kern.info kernel: [445788.136746] RTL8380 Link change: status: 1, ports 2000
4840 Tue Nov 10 10:38:38 2026 kern.info kernel: [445788.142758] rtl83xx-switch switch@1b000000 port6: Link is Down
4841 Tue Nov 10 10:38:38 2026 kern.info kernel: [445788.152706] br0: port 6(port6) entered disabled state
4842 Tue Nov 10 10:38:38 2026 kern.info kernel: [445788.251519] rtl83xx-switch switch@1b000000 port6: Link is Up - 100Mbps/Full - flow control off
4843 Tue Nov 10 10:38:38 2026 kern.info kernel: [445788.261504] br0: port 6(port6) entered blocking state
4844 Tue Nov 10 10:38:39 2026 kern.info kernel: [445788.594741] rtl83xx-switch switch@1b000000 port6: Link is Down
4845 Tue Nov 10 10:38:39 2026 kern.info kernel: [445788.601658] br0: port 6(port6) entered disabled state
4846 Tue Nov 10 10:38:39 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4847 Tue Nov 10 10:38:39 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering blocking state
4848 Tue Nov 10 10:38:39 2026 daemon.notice netifd: Network device ‘port6’ link is down
4849 Tue Nov 10 10:38:40 2026 daemon.notice netifd: Network device ‘port6’ link is up
4850 Tue Nov 10 10:38:40 2026 daemon.notice netifd: Network device ‘port6’ link is down
4851 Tue Nov 10 10:38:40 2026 network.notice Network device ‘port6’ entering blocking STP state
4852 Tue Nov 10 10:38:40 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4853 Tue Nov 10 10:38:40 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4854 Tue Nov 10 10:38:41 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port6:0 Flushing forwarding database
4855 Tue Nov 10 10:38:41 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4856 Tue Nov 10 10:38:41 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4857 Tue Nov 10 10:38:41 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4858 Tue Nov 10 10:38:41 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering learning state
4859 Tue Nov 10 10:38:42 2026 network.notice Network device ‘port6’ entering learning STP state
4860 Tue Nov 10 10:38:42 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
4861 Tue Nov 10 10:38:42 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port6 Couldn’t set kernel bridge state learning
4862 Tue Nov 10 10:38:42 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4863 Tue Nov 10 10:38:42 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4864 Tue Nov 10 10:38:43 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering blocking state
4865 Tue Nov 10 10:38:43 2026 network.notice Network device ‘port6’ entering blocking STP state
4866 Tue Nov 10 10:38:43 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port6:0 Flushing forwarding database
4867 Tue Nov 10 10:38:43 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4868 Tue Nov 10 10:38:43 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4869 Tue Nov 10 10:38:44 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4870 Tue Nov 10 10:38:44 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : down
4871 Tue Nov 10 10:38:44 2026 network.notice Port link state of port port6 changed to DOWN
4872 Tue Nov 10 10:38:44 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
4873 Tue Nov 10 10:38:44 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
4874 Tue Nov 10 10:38:46 2026 user.info : Finished database optimization
4875 Tue Nov 10 10:38:51 2026 kern.info kernel: [445801.827996] RTL8380 Link change: status: 1, ports 1000
4876 Tue Nov 10 10:38:52 2026 kern.info kernel: [445802.168538] rtl83xx-switch switch@1b000000 port5: Link is Up - 100Mbps/Full - flow control off
4877 Tue Nov 10 10:38:52 2026 kern.info kernel: [445802.178528] br0: port 5(port5) entered blocking state
4878 Tue Nov 10 10:38:52 2026 daemon.notice netifd: Network device ‘port5’ link is up
4879 Tue Nov 10 10:38:52 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4880 Tue Nov 10 10:38:52 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4881 Tue Nov 10 10:38:52 2026 network.notice Port link state of port port5 (100 baseT) changed to UP
4882 Tue Nov 10 10:38:54 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering learning state
4883 Tue Nov 10 10:38:54 2026 network.notice Network device ‘port5’ entering learning STP state
4884 Tue Nov 10 10:38:55 2026 kern.info kernel: [445805.212150] br0: port 5(port5) entered learning state
4885 Tue Nov 10 10:38:55 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering forwarding state
4886 Tue Nov 10 10:38:55 2026 network.notice Network device ‘port5’ entering forwarding STP state
4887 Tue Nov 10 10:38:55 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4888 Tue Nov 10 10:38:55 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
4889 Tue Nov 10 10:38:56 2026 kern.info kernel: [445805.774917] br0: port 5(port5) entered forwarding state
4890 Tue Nov 10 10:39:04 2026 kern.info kernel: [445814.965162] RTL8380 Link change: status: 1, ports 2000
4891 Tue Nov 10 10:39:05 2026 kern.info kernel: [445815.532014] rtl83xx-switch switch@1b000000 port6: Link is Up - 100Mbps/Full - flow control off
4892 Tue Nov 10 10:39:05 2026 kern.info kernel: [445815.542008] br0: port 6(port6) entered blocking state
4893 Tue Nov 10 10:39:05 2026 daemon.notice netifd: Network device ‘port6’ link is up
4894 Tue Nov 10 10:39:05 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4895 Tue Nov 10 10:39:06 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4896 Tue Nov 10 10:39:06 2026 network.notice Port link state of port port6 (100 baseT) changed to UP
4897 Tue Nov 10 10:39:07 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering learning state
4898 Tue Nov 10 10:39:07 2026 network.notice Network device ‘port6’ entering learning STP state
4899 Tue Nov 10 10:39:08 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port6:0 entering forwarding state
4900 Tue Nov 10 10:39:08 2026 kern.info kernel: [445818.292564] br0: port 6(port6) entered learning state
4901 Tue Nov 10 10:39:08 2026 network.notice Network device ‘port6’ entering forwarding STP state
4902 Tue Nov 10 10:39:08 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4903 Tue Nov 10 10:39:08 2026 daemon.info tswconfig[2296]: set_if_up: Port port6 : up
4904 Tue Nov 10 10:39:09 2026 kern.info kernel: [445818.849511] br0: port 6(port6) entered forwarding state
Turning off POE on switch port2 (no issues) -
5170 Tue Nov 10 10:45:35 2026 events.notice CONFIG: User “admin” changed Poe configuration in “network/ports/ports-settings” page
5171 Tue Nov 10 10:45:36 2026 kern.info kernel: [446207.154114] RTL8380 Link change: status: 1, ports 200
5172 Tue Nov 10 10:45:37 2026 kern.info kernel: [446207.164409] rtl83xx-switch switch@1b000000 port2: Link is Down
5173 Tue Nov 10 10:45:37 2026 kern.info kernel: [446207.171329] br0: port 2(port2) entered disabled state
5174 Tue Nov 10 10:45:37 2026 kern.info kernel: [446207.269182] rtl83xx-switch switch@1b000000 port2: Link is Up - 100Mbps/Full - flow control off
5175 Tue Nov 10 10:45:37 2026 kern.info kernel: [446207.279164] br0: port 2(port2) entered blocking state
5176 Tue Nov 10 10:45:37 2026 kern.info kernel: [446207.640292] rtl83xx-switch switch@1b000000 port2: Link is Down
5177 Tue Nov 10 10:45:38 2026 kern.info kernel: [446207.647213] br0: port 2(port2) entered disabled state
5178 Tue Nov 10 10:45:38 2026 daemon.notice netifd: Network device ‘port2’ link is down
5179 Tue Nov 10 10:45:38 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5180 Tue Nov 10 10:45:38 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering blocking state
5181 Tue Nov 10 10:45:38 2026 daemon.notice netifd: Network device ‘port2’ link is up
5182 Tue Nov 10 10:45:39 2026 daemon.notice netifd: Network device ‘port2’ link is down
5183 Tue Nov 10 10:45:39 2026 network.notice Network device ‘port2’ entering blocking STP state
5184 Tue Nov 10 10:45:39 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
5185 Tue Nov 10 10:45:39 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
5186 Tue Nov 10 10:45:39 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port2:0 Flushing forwarding database
5187 Tue Nov 10 10:45:40 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5188 Tue Nov 10 10:45:40 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5189 Tue Nov 10 10:45:40 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
5190 Tue Nov 10 10:45:40 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering learning state
5191 Tue Nov 10 10:45:40 2026 network.notice Network device ‘port2’ entering learning STP state
5192 Tue Nov 10 10:45:41 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
5193 Tue Nov 10 10:45:41 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port2 Couldn’t set kernel bridge state learning
5194 Tue Nov 10 10:45:41 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : up
5195 Tue Nov 10 10:45:41 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5196 Tue Nov 10 10:45:42 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port2:0 entering blocking state
5197 Tue Nov 10 10:45:42 2026 network.notice Network device ‘port2’ entering blocking STP state
5198 Tue Nov 10 10:45:42 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port2:0 Flushing forwarding database
5199 Tue Nov 10 10:45:42 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5200 Tue Nov 10 10:45:42 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5201 Tue Nov 10 10:45:43 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5202 Tue Nov 10 10:45:43 2026 daemon.info tswconfig[2296]: set_if_up: Port port2 : down
5203 Tue Nov 10 10:45:43 2026 network.notice Port link state of port port2 changed to DOWN
5204 Tue Nov 10 10:45:43 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
5205 Tue Nov 10 10:45:44 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
Turning off POE on switch port5 (no issues) -
5131 Tue Nov 10 10:43:32 2026 events.notice CONFIG: User “admin” changed Poe configuration in “network/ports/ports-settings” page
5132 Tue Nov 10 10:43:33 2026 kern.info kernel: [446084.080969] RTL8380 Link change: status: 1, ports 1000
5133 Tue Nov 10 10:43:34 2026 kern.info kernel: [446084.091348] rtl83xx-switch switch@1b000000 port5: Link is Down
5134 Tue Nov 10 10:43:34 2026 kern.info kernel: [446084.098285] br0: port 5(port5) entered disabled state
5135 Tue Nov 10 10:43:34 2026 kern.info kernel: [446084.279588] rtl83xx-switch switch@1b000000 port5: Link is Up - 100Mbps/Full - flow control off
5136 Tue Nov 10 10:43:34 2026 kern.info kernel: [446084.289572] br0: port 5(port5) entered blocking state
5137 Tue Nov 10 10:43:34 2026 kern.info kernel: [446084.473039] rtl83xx-switch switch@1b000000 port5: Link is Down
5138 Tue Nov 10 10:43:35 2026 kern.info kernel: [446084.479946] br0: port 5(port5) entered disabled state
5139 Tue Nov 10 10:43:35 2026 daemon.notice netifd: Network device ‘port5’ link is down
5140 Tue Nov 10 10:43:35 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5141 Tue Nov 10 10:43:35 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering blocking state
5142 Tue Nov 10 10:43:35 2026 daemon.notice netifd: Network device ‘port5’ link is up
5143 Tue Nov 10 10:43:35 2026 daemon.notice netifd: Network device ‘port5’ link is down
5144 Tue Nov 10 10:43:36 2026 network.notice Network device ‘port5’ entering blocking STP state
5145 Tue Nov 10 10:43:36 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
5146 Tue Nov 10 10:43:36 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
5147 Tue Nov 10 10:43:36 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port5:0 Flushing forwarding database
5148 Tue Nov 10 10:43:36 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5149 Tue Nov 10 10:43:37 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5150 Tue Nov 10 10:43:37 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
5151 Tue Nov 10 10:43:37 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering learning state
5152 Tue Nov 10 10:43:37 2026 network.notice Network device ‘port5’ entering learning STP state
5153 Tue Nov 10 10:43:38 2026 daemon.err tswconfig[2296]: rtnl_talk: RTNETLINK answers
5154 Tue Nov 10 10:43:38 2026 daemon.err tswconfig[2296]: MSTP_OUT_set_state: br0:port5 Couldn’t set kernel bridge state learning
5155 Tue Nov 10 10:43:38 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : up
5156 Tue Nov 10 10:43:38 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5157 Tue Nov 10 10:43:38 2026 daemon.info tswconfig[2296]: MSTP_OUT_set_state: br0:port5:0 entering blocking state
5158 Tue Nov 10 10:43:39 2026 network.notice Network device ‘port5’ entering blocking STP state
5159 Tue Nov 10 10:43:39 2026 daemon.info tswconfig[2296]: MSTP_OUT_flush_all_fids: br0:port5:0 Flushing forwarding database
5160 Tue Nov 10 10:43:39 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5161 Tue Nov 10 10:43:39 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5162 Tue Nov 10 10:43:39 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5163 Tue Nov 10 10:43:40 2026 daemon.info tswconfig[2296]: set_if_up: Port port5 : down
5164 Tue Nov 10 10:43:40 2026 network.notice Port link state of port port5 changed to DOWN
5165 Tue Nov 10 10:43:40 2026 daemon.notice netifd: dhcp (2938): udhcpc: sending renew to server 192.168.1.3
5166 Tue Nov 10 10:43:40 2026 daemon.notice netifd: dhcp (2938): udhcpc: lease of 192.168.1.106 obtained from 192.168.1.3, lease time 86400
Additional testing -
ls -la /sys/class/poe/
drwxr-xr-x 2 root root 0 Nov 10 15:35 .
drwxr-xr-x 24 root root 0 Nov 10 15:35 ..
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 chip0 → ../../devices/platform/i2c-gpio-2/i2c-2/2-0077/poe/chip0
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 chip1 → ../../devices/platform/i2c-gpio-2/i2c-2/2-0027/poe/chip1
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 chip2 → ../../devices/platform/i2c-gpio-2/i2c-2/2-002f/poe/chip2
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port1 → ../../devices/platform/i2c-gpio-2/i2c-2/2-002f/poe/port1
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port2 → ../../devices/platform/i2c-gpio-2/i2c-2/2-002f/poe/port2
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port3 → ../../devices/platform/i2c-gpio-2/i2c-2/2-002f/poe/port3
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port4 → ../../devices/platform/i2c-gpio-2/i2c-2/2-002f/poe/port4
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port5 → ../../devices/platform/i2c-gpio-2/i2c-2/2-0027/poe/port5
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port6 → ../../devices/platform/i2c-gpio-2/i2c-2/2-0027/poe/port6
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port7 → ../../devices/platform/i2c-gpio-2/i2c-2/2-0027/poe/port7
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 port8 → ../../devices/platform/i2c-gpio-2/i2c-2/2-0027/poe/port8
lrwxrwxrwx 1 root 905 0 Nov 2 13:23 sys → ../../devices/virtual/poe/sys
ls /sys/devices/platform/i2c-gpio-2/i2c-2/2-002f/poe
chip2 port1 port2 port3 port4
ls /sys/devices/platform/i2c-gpio-2/i2c-2/2-0027/poe/
chip1 port5 port6 port7 port8
uci set poe.port4.poe_enable=‘0’ && /etc/init.d/poeman reload
16:17:07
port_nr channel detected class enable state status current voltage power_usage
port1: 3 1 4 1 up 1 46848 53775 2413
port2: 2 1 4 1 up 1 175680 54522 9578
port3: 1 1 4 1 up 1 56608 53962 3054
port4: 0 1 4 1 up 1 187392 53588 9726
16:17:10
port1: 3 0 -1 1 falling 0 5856 0 1
port2: 2 0 -1 1 down 0 5856 560 3
port3: 1 0 -1 1 falling 0 5856 0 0
port4: 0 1 4 0 ready 0 3904 560 2
16:17:26
port1: 3 1 4 1 up 1 54656 53775 2833
port2: 2 1 4 1 up 1 70272 54522 3724
port3: 1 1 4 1 up 1 62464 53962 3475
uci set poe.port8.poe_enable=‘0’ && /etc/init.d/poeman reload
16:26:22
port5: 3 1 3 1 up 1 52704 53962 2738
port6: 2 1 2 1 up 1 42944 53962 2422
port7: 1 1 4 1 up 1 9760 53962 947
port8: 0 1 2 1 up 1 42944 53401 2188
16:26:25
port5: 3 0 -1 1 falling 0 5856 0 0
port6: 2 0 -1 1 falling 0 5856 186 1
port7: 1 0 -1 1 falling 0 5856 0 0
port8: 0 1 2 0 ready 0 3904 560 2
16:26:41
port5: 3 1 3 1 up 1 48800 53962 2633
port6: 2 1 2 1 up 1 42944 53962 2317
port7: 1 1 4 1 up 1 23424 53962 1368
Switch ports 4 and 8 are both on channel 0.
