TSW202 poe power usage API
I am using https://developers.teltonika-networks.com/reference/tsw202/1.6.2/v1.2.1/ports-settings#get-ports_settings-status
Unfortunately, it looks the power usage returned is 1 or 0 instead of the real usage in watt.
Do you experience the same ? I use the latest FW version 1.6.2
it looks “budget” returns the data i search for
still - this is confusing
Good afternoon,
Thank you for your query.
We are currently working on it, and will be back with a response as soon as possible.
Thank you for your patience,
Teltonika Team
Good afternoon,
After checking, I can confirm that the budget tab will return your desired values.
Please advise if you have any further queries.
Arturas
