TSW202 IPv6 Multicast not working as expected
Hello there,
I am in the process of standing up a Rajant Kinetic Mesh network and the decision was made to use Teltonika TWS202 switches in our comms trailers. During the commissioning process I noticed that the Rajant nodes are not discovering each other via their Ethernet ports which are connected via the TSW202 switches, where as a direct Ethernet connection between two nodes allows this to happen. The Rajant documentation states that the node discovery process occurs over IPv6 Multicast. I have found some topics here that mention issues regarding IPv6 Multicasting on TSW202 switches but no solutions. Does Teltonika have any plans moving forward to address this issue?
Thanks and Regards,
David
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16196.
