My TSW202 doesn’t forward any traffic apperently.
Devices connected to the router through TSW202 are not getting an IP nor can those communicate with devices ‘on the other side’ when they have fixed IP.
Even after factory reset no change in that. Manually uploading a firmware didn’t change anything either.
If anyone has an idea why ‘nothing’ works, your help is welcome.
You have to enable DHCP server for TSW202. It is under Network → DHCP. Once it is set up, end devices should get IP from the given range. More information about TSW202 DHCP here.
