I see in the release notes for FW TSW2_R_00.01.04 that ‘dot1dTpFdbEntry’ OID support was added.
It doesn’t appear to be working. I see no entries under .1.3.6.1.2.1.17.4.3.1.
I SNMP v1 and V2 enabled, tried both.
Anything else I might be missing?
Thank you for reaching out and for sharing this observation.
Could you specify which firmware version you’re currently testing the dot1dTpFdbEntry OID with? At the moment, this functionality should properly work only with TSW2_R_00.01.04, as there’s a known issue in later firmware versions where this OID doesn’t populate correctly. This bug has been reported to our R&D team, and I’ll make sure to keep you updated as soon as there’s progress or a fix available.
Once again, I truly appreciate you bringing this to our attention and your patience while this is being addressed.
I am using the latest firmware: 1.05.1
