My TRB500 is dropping in connection speed after some hours of use. I’ve tried to put it to passthrough instead of NAT which seems to have improved the connection, but still not stable. I noticed the modem firmware it’s running is “RG501QEUAAR12A05M4G_OCPU_BETA-20211020D-04.001.00.000” which seems very old. Is there a way to find a stable firmware update?
Is there no way to update the modem firmware? I’m relying on the TRB500 for work and need the connection to be stable. Can’t continue to restart it several times a day. Is there any other product that is more stable than the TRB500? How about the RUTX50 or the TRB501?
For troubleshooting purposes, could you please provide us with the device’s current mobile signal values? Specifically, please navigate to Status → Network → Mobile in the device WebUI and provide the RSSI, RSRP, RSRQ, and SINR values.
Additionally, could you please let us know whether any antennas are connected to the device? If so, please confirm whether you are using the antennas supplied with the device or third-party antennas.
This information will help us narrow down the possible cause of the issue and determine the next troubleshooting steps.
We appreciate your patience and look forward to your response.
I can only speak for the TRB501, and unfortunately I can’t recommend it as a more stable option.
In my experience it has its own problems: intermittent UDP packet loss on 5G NSA, no hardware offload in bridge mode, and in NAT mode the offload works but stops after a while — I had to script a bridge → NAT mode switch to restore it. Without working hardware offload the device isn’t usable for me, so I’m afraid it wouldn’t solve your problem either.
We understand that issues such as these can be frustrating, especially when the device is being relied upon for a stable connection.
We acknowledge that there can be issues with our devices from time to time. Our products are continuously being updated and improved to address issues and improve overall stability and performance.
We sincerely apologize for the inconvenience this has caused and appreciate your patience and understanding while we continue working on improving our products.
