TRB500 problems with latest firmware TRB500_R_00.07.12.3
I updated from TRB500_R_00.07.11 to TRB500_R_00.07.12.3 couple of days ago and have since gotten quite a lot of disconnects (and ping reboots), also once the modem took 2-3 minutes to ping reboot. I can send you the logs if interested, but should I revert back and into what version?
Thank you for reaching out.
I’d like to investigate your issue more in depth. For this, I’ve sent you a form to fill out, which should be received in the inbox of the email used for your forum registration. When completing it, please use 12548 as the ticket ID. Once submitted, we’ll contact you privately to assist and troubleshoot this matter further.
Thanks, meanwhile is it safe or possible to roll back firmware?
So, my modem firmware was quite old, and after updating that, the newest TRB500_R_00.07.13.1 works like a charm. Thanks for help @anon65719490 !
