Hi, I’m having a tiny problem with TRB500 and its modem crashing constantly. Issues started 2 weeks ago 31.12.2025 after changing to different ISP and before that no problems at all. I’ve tried different firmwares: TRB500_R_00.07.18.3, TRB500_R_00.07.19.4 and TRB500_R_00.07.20.1. Logs show a fatal modem error repeating:
753 Fri Jan 16 09:37:48 2026 kern.err kernel: [ 160.319383] Fatal error on modem!
754 Fri Jan 16 09:37:48 2026 kern.err kernel: [ 160.319453] modem subsystem failure reason: trm_rf_alloc.cpp:942:RF alloc returned FALSE for num_carriers: 3 sub_capability 0.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17364.
