the implications and advice on what is most suitable to me
hear how to solve some needs
Lets start at the top and I’ll provide info as we progress.
The difference of bridge and passthrough modes
If there is any link to a good explanation that would be awesome.
When on the admin page /network/wan and setting the mode for WAN the description below is given
Using Bridge or Passthrough mode will disable most of the device capabilities and you can access your device’s settings only through its static IP address!
using Bridge mode will disable most of the router’s other capabilities (NAT, Firewall, DHCP server…) and router will not have internet, will not be accessible through the RMS platform
The implications and advice on what is most suitable to me
My current setup is with the TRB500 in bridge mode and used as WAN connection for a Ubiquiti UDM-SE.
Some needs/limitations I’ve noticed and would like to either overcome or get explained.
the package manager at /system/packages/packages show no packages available, nor installed
Welcome to Teltonika Networks Community !
Kindly refer to the below posts for a better understanding of Bridge and Passthrough modes.
The main difference between Passthrough and Bridge is that in Passthrough, the router’s DHCP Server still works and the regular LAN interface is still up, allowing clients to connect to the router’s local network as usual and the connected devices will have WAN access too, while Bridge mode disables all of these features and simply gives the a single specified device its WAN IP address, but if DHCP is enabled the devices connected will only have local access.
The issues you are facing can be resolved by using passthrough mode instead.
Also an important point, i would advise you to retest using the latest FW TRB500_R_00.07.06.1 , as it comes with a patch that greately enhances Passthrough and Bridge modes.
Thanks for you reply. I’ll digest the information you liked to.
The following section cause some confusion.
The experience in bridge mode in my set up seem to match what you describe about passthrough.
My UDM-SE get the IP address of the TRB500
The TRB500 is reachable from the internal network using 192.168.0.1
Is it that for TRB500 there is no difference between bridge or passthrough?
Apologies, it was incorrect, i have revised it.
Basically - In Passthrough and Bridge DHCP works, but in passthrough the connected LAN devices will have WAN Access, while in Bridge mode its just internally the devices will be connected to each other only and one device will have exclusive WAN Access.
Correct, it was later agreed in the later comments. The WebUI can be accessed in Bridge mode if the existing routes are present or a static IP or route is set.
