I need to block data roaming, to block data transfer to/from the internet, when Connection → Operator state is “Roaming”,
My TRB500 Mobile → “SIM-card setting” “Deny data roaming” option is “On”, but allows data transfer in this case, it is reachable remotely and it can ping any internet host for example.
What is wrong, misunderstand or misconfigure by me?
Hello, what is registration status to the network? Could you post info from WebUI when you in Status → Network → Mobile? Are you sure that current state is “Roaming”?
The “Deny data roaming” logic works correctly when the mobile connection restarts manually.
I need to block data connection in roaming without any manual manipulations.
Last two changes of mobile operators in roaming didn’t block data connection
PS: I’ll be able to check roaming behavior again tomorrow at least.
This issue occurs when TRB500 switches from home to roaming and when it switches between roaming operators as well.
PS: I’m not sure if I should create new topic, but is it possible to handle switching between operators, to identify home/roaming connection status by something, by hotplug for example, to do something on event?
My TRB500 didn’t handle the “Deny data roaming” → “On” logic correctly today, it didn’t block data connection after switching from home to roaming network.
Is it possible to fix this issue? Do you have any solution to solve this issue?
