TRB500 and UDM PRO network configuration
Hello everybody, im glad to join this community.
I need some help or hint about the network configuration of my devices.
It the moment i have TRB500 in bridge mode connected to UDM PRO acting as a router.
TRB500 have default lan port 192.168.2.1… The netwoek behind the UDM is 192.168.1.0/24 and after adding the routing rule at the UDM i am able to reach 192.168.2.1 from lan easly.
But the problem is for me to setup the routing in the way that TRB500 would be able to access the 192.168.1.0 network behind the UDM. Any hint here?
Im trying to setupe the MQTT on TRB to publish the data to mosquito broker 192.168.1.89, but at the moment it cannot connect and i think i cannot deal with it with myself, also im not sure if its possible.
Thanks for any advice :slightly_smiling_face:
To achieve your goal, consider adding a route from a TRB500 to your UDM. You can find detailed instructions on configuring routing between devices on our wiki page: TRB500 Routing.
Let me know if you need further assistance!
