Hi All,
I have the Modbus TCP client periodically retrieving data from a device, using multiple “reads”.
My problem is, I can only set the read interval (period) at the device level, not the request level.
I can disable certain request so that they are not read periodically. Is there a way to trigger these request using a MQTT command (MQTT gateway or through the dataserver or using a script)?
