TRB256 – All LEDs all fixed, no WebUI access, no Wifi connectivity
I am having a critical issue with my Teltonika TRB256 and I can no longer access the device.
Problem description
When I connect the TRB256 to my PC via Ethernet, the following happens:
  1. At first, all LEDs were blinking.
  2. After attempting several reboots and a factory reset, all LEDs are now all on and stady.
  3. I cannot access the WebUI at 192.168.1.1 (also wi-fi router adress) or 192.168.10.1 previously configured.
  4. My PC does not receive an IP address from the TRB256 (it cuts the wi-fi as soon as it is powered).
  5. The LAN port LEDs sometimes blink when I plug the cable, but I still cannot reach the device.
  6. Factory reset (holding the reset button for 10–15 seconds) did not solve the issue.
What I have tried
  • Power cycling the gateway.
  • Performing a proper factory reset (holding RESET but LEDs don’t change).
  • Connecting directly via Ethernet with Wi-Fi disabled.
  • Trying to access possible recovery mode at http://192.168.1.1.
  • Different Ethernet cables.
Current status
  • The TRB256 does not boot normally.
  • All LEDs on together, fixed.
  • I cannot reach the device in any way.
  • It may be stuck in a corrupted firmware boot loop or recovery mode.
Any guidance would be greatly appreciated.
Thank you!
If you have followed the instructions on how to factory reset the device TRB256 Device Recovery Options - Teltonika Networks Wiki
And that still doesn’t work. In this case, it is a hardware issue, and you should proceed with the RMA procedure, for warranty repairs. If you purchased through a vendor, please contact them for further assistance with the RMA procedure. Here you can find more information about RMA procedure: RMA - Teltonika Networks Wiki
If you have bought the device directly from us, then contact us through HelpDesk or contact your sales manager.
I recommend mentioning the serial number in the first message when you contact the vendor or us, so it saves you some time.
