I have a setup using TRB246 (192.168.47.15).
NTP Time synchronization is off. Operator tiem sync is off.
I enabled GPS Time sync every 5 minuters.
I enable NTP time server.
NMEA sentence forwaring is on.
I DISCONNECTED the GPS cable.
when I do a NTP Query to the TRB, it returns a timestamp and stratum 1. This is a violation and effectively makes the device unusable for GPS time synchronization.
root@gandalf:/home/hans# netcat -k -l -u 192.168.47.114 8500
$GPGGA,,,,,,0,,,,,,,,*66
$GPRMC,,V,,,,,,,,,,N,V*29
The first line tells, that the GPS has no fix. The second tells, that no GPS-Timesstamp is available.
root@gandalf:/home/hans# ntpdig 192.168.47.15
2026-05-15 10:57:20.616609 (+0200) +7179.698780 +/- 0.002363 192.168.47.15 s1 no-leap
“s1” means, that the TRB246 NTP Server is claiming to be a stratum 1, even 5 minutes after GPS has been disconnected.
My expectation is taht it should return stratum16.
