TRB245 RS485 recieve problem
i have a trb246 running where i want to connect an waveshare modbus rtu 8ch io board via rs485.
I’m currently developing a custom openwrt package for it but can’t get the modbus to run.
I’m using 9600 baud, with 8 data and 1 stop bit with No Parity as described in the waveshare wiki with device id 1.
When i send some command over modbus i can see the rxd led on the waveshare board flicker and immediatly the txd flickers.
But ultimately the data is never recieved in my c programm.
I can’t really inspect anything.
Can’t i use the rs485 in my on programm? Or do i need to be aware of any special settings? I can’t really find a documentation for this in combination with the provided sdk.
Thanks for your help
As custom-written SDKs & packages are quite advanced, and are out of our technical support scope, I’m not able to comment much or give you good suggestions. I may try to reach out to our R&D to see if they’d be able to help, but it’s not a guarantee.
Some additional information, that may come in handy, is that we have a Wiki for compiling the custom SDK that you’re building: RUTOS Software Development Kit (SDK) Instruction - Teltonika Networks Wiki
As the TRB has RS485 support, in theory, you should have no issues utilizing it. The issue may derive from something else.
