TRB245 not connecting to RMS
Firmware current. Did factory reset.
Unregistered from management devices then added device again.
Connection log for this unit has repeated events of “The device is redirected to the authentication system.” with Status codes of 20 and 0.
Can you check if it is blocked on RMS?
Nevermind I fixed it.
Auto APN selected incorrect network. Only ipv6 was running with no ipv4 on qmimux0 interface
