TRB245 GPS not working after update to TRB2_R_00.07.05.4. Was working prior to update.
GPS also not working with firmware TRB2_R_00.07.05 but does work with TRB2_R_00.07.04.5
Hello Teltonika, is anyone reading these forums??? Still no reply!!!
First of all - Sorry for the late reply, hope this message finds you well.
I tried out the TRB245 with the firmwares you mentioned, and it looks like the GPS is functioning well. You mentioned that after updating your firmware, it stopped working. If you chose the “keep settings” option during the update, it might have caused a problem with the new configurations. I recommend resetting the device and checking the GPS again. Don’t forget to turn GPS functionality on again after the reset. Hopefully, this resolves your issue.
Best wishes,
Marijus
