TRB235 NMEA forwarding fails
After 2500 NMEA serial forwards, the serial forwarding fails. The forwarding just stops.
Work around is to reboot router with cron evey 59mins.
Please fix the serial forwarding buffer.
Thank you for reaching out.
Could you please specify which firmware version is currently installed on your TRB245/255? If you are using an older release, I recommend updating to the latest firmware TRB2_R_00.07.12 to check whether the described NMEA forwarding behavior persists.
Looking forward to your response.
Yes I am using 07.12.
To replicate turn on serial forwarding $GPGGA & GPRMC. Say 1 per second. Period doesn’t really matter just quicker to test. RS232 port at 4800bd. Will stop when number of forwards gets to 2500.
Thank you for your patience. Our developers are aware of this issue, and it is expected to be resolved with the 7.14 firmware release.
If you have any further questions or need assistance in the meantime, please feel free to reach out.
