I have purchased and run a TRB160 4G LTE in IPv4 mode with success (bridge mode) with a Unifi Ultra behind it. it’s fine !
When trying IPV4/IPV6 configuration, only the IPv6 (and prefix delegation as well) is provided in the WAN interface… no more the IPv4 one !!
Thank you for reaching out. In this case, to assist you effectively, we’ll need to continue this process privately, because sensitive/publicly unshareable information needs to be gathered. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14773 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
My Modem Firmware EG060KEAAAR01A01M2G_OCPU_BETA240123_01.200.00.000 seems to be the latest, but IPv4/IPv6 mode does not work…
I have to go back to IPv4 only …
Waiting for more info in the future …
