TRB145 - LTE modem good signal but disconnected
my TRB145 give “disconnect” as mobile status; below the screenshot:
immagine
the signal it seems ok but cant connect and in the events logs i see " Mobile data disconnected (internal modem)"
and this is the output for modem:
root@HOST:~# uqmi -d /dev/cdc-wdm0 --get-data-status
"connected"
root@HOST:~# uqmi -d /dev/cdc-wdm0 --get-serving-system
        "registration": "registered",
        "CS": "attached",
        "PS": "attached",
        "plmn_mcc": 222,
        "plmn_mnc": 88,
        "plmn_description": "פ�H�\u0016\u0001",
        "roaming": false,
        "status": "available"
root@HOST:~#
furthermore
Tue Jun 25 23:53:37 2024 daemon.notice netifd: mob1s1a1 (640): pdh4: Reason type not found"
Tue Jun 25 23:53:37 2024 daemon.notice netifd: mob1s1a1 (640): "No effect"
Tue Jun 25 23:53:37 2024 daemon.notice netifd: mob1s1a1 (640): Unable to connect IPv4
Tue Jun 25 23:53:37 2024 daemon.notice netifd: mob1s1a1 (640): Releasing client-id 1 on /dev/cdc-wdm0
Tue Jun 25 23:53:37 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 30000 --set-client-id wds,1 --release-client-id wds
Tue Jun 25 23:53:37 2024 daemon.notice netifd: mob1s1a1 (640): Failed to create IPV4 connection
Tue Jun 25 23:53:37 2024 daemon.info dnsmasq[4742]: read /etc/hosts - 4 addresses
Tue Jun 25 23:53:37 2024 daemon.info dnsmasq[4742]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Tue Jun 25 23:53:37 2024 daemon.info dnsmasq-dhcp[4742]: read /etc/ethers - 0 addresses
Tue Jun 25 23:53:47 2024 daemon.notice netifd: mob1s1a1 (1202): Stopping network mob1s1a1
Tue Jun 25 23:53:47 2024 daemon.notice netifd: mob1s1a1 (1202): Command failed: Not found
Tue Jun 25 23:53:47 2024 daemon.notice netifd: mob1s1a1 (1202): Command failed: Permission denied
is there any troubleshooting to be done to understand the problem? any Idea?
thanks
Make sure you are using the correct APN for your mobile carrier. To find the correct APN, contact your mobile carrier or check their troubleshooting/info page. You can change the APN setting on the TRB145 by going to Network → WAN and pressing the “Edit” button next to the desired mobile interface. In the new pop-up window, uncheck “Auto APN” and input the custom APN.
Thanks Marius,
but I have found the problem; it seems that the configuration of the interface was not the correct one. Below the right conf:
config interface 'mob1s1a1'
        option proto 'connm'
        option modem '3-1'
        option metric '1'
        option sim '1'
        option dhcpv6 '0'
        option pdptype 'ip'
        option method 'nat'
        option _area_type 'wan'
        option device 'rmnet0'
        option pdp '1'
        option auto_apn '0'
        option force_apn '-1'
        option password 'abcabcabc'
        option username 'abcabcabcabcabc
        option apn 'apn.abc.abc'
        option delegate '1'
        option force_link '0'
        option auth 'chap'
        option pref_apn '267'
below the previous wrong conf:
        option modem '3-1'
        option metric '2'
        option sim '1'
        option dhcpv6 '0'
        option pdptype 'ip'
        option method 'nat'
        option ifname 'rmnet0'
        option apn 'abcabcabc'
        option username 'abcabcabc'
        option delegate '1'
        option auto_apn '0'
        option auth 'chap'
        option pdp '1'
I have created by using the gui a new interface and I have performet a diff between the newone configuration file and the oldone
