TRB143 - Mbus client data to user Modbus registers
I have configured Mbus client to polls Mbus Sharky 775 device. I can see values in the table if I use “Load available parameters” option. If create a list of parameters based on Frame, record and name and TEST configuration there are no parameter values in the table but they can be showed as JSON or CSV or ASCII type. I also have configured MBUS TCP server and use MBUS as data source, and configure every user odbus register u get value of a certain MBUS parameter from the defined list. But.. modbus registers always have a value 0x00 / 0x0000 or empty string ( I have tried all options).
Does the TRB143 support that configuration or not?
Best regards
Predrag Pavosevic, Croatia
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17462.
I found that there are no written data to file that contains values of the user defined modbus registers.
If I write something manually to this file I can read a data from defined register using modbus client simulator.
BR
Predrag
I will enter my official email address in the form on the provided link.
BR
Predrag
What additional information / log files you need for the troubleshooting this? Could you send me short instruction how I can capture them?
BR
Predrag
I have sent you an email, please reply to it with the necessary information.
