TRB143 M-BUS not working on wM RF module
Dear community.
After my old m-bus master broke down, I bought a TRB143 to read my m-bus meters. Meters that are wired directly work ok, but the Kamstrup MC 21 water meters that use an RF wM-Bus Dongle converter are not visible inside the TRB143. I use an M-bus USB Master to check if I receive data from the dongle and I do.
Is it possible to make more settings in the TRB143 so that it can see the meter from the wM-Bus Dongle?
Hey!
The underlying software the Teltonika uses is called wmbusmeters. It should totally read your device if it is following the oms standard. Are you sure that’s the case?
Anyway, you can log in to your Teltonika via SSH and execute wmbusmeters commands directly on the device switching around parameters.
Best, DK
Thanks for the response, this was helping me in the right direction. Thanks a lot.
