TRB143 – Is it possible to send custom values to RMS?
I’m using a TRB143 with Teltonika RMS, and I can see all the usual system parameters (signal, CPU, I/O, etc.).
Now I’d like to display custom values in RMS — for example, data coming from Node-RED or an external sensor.
On devices like the TRB255 or RUT routers, there’s a “Data to RMS” feature to send Modbus or UCI values to RMS, but I can’t find this option on the TRB143.
:backhand_index_pointing_right: Is there any way to send custom data or overwrite system parameters so they appear in RMS on the TRB143?
Or is this simply not supported on this model?
Thanks in advance for any clarification!
Sven
You can use monitoring templates in RMS. For example, Modbus already includes preset endpoints that you can easily select when creating a template. For other types of custom data, you may need to implement a custom solution.
You can find more information and detailed instructions about monitoring templates here:
