TRB142 Report Signal Strength
Is there any way to get the TRB142 to report signal strength periodically via MQTT or similar low-bandwidth protocol? The MQTT publisher on the TRB142 seems lacking in functionality.
Hello David42,
Yes, our software has a built in service called ‘Data to Server’ that you can use to send that data on a regular interval via the MQTT protocol.
You can find configuration information here at our Wiki ( RUTX11 Data to Server - Teltonika Networks Wiki ).
My recommendation is that you send GSM data with RSRP & RSRQ data to your MQTT broker of choice.
Additionally this information can be collected via our RMS platform (https://rms.teltonika-networks.com/).
Where a device can be added for free for 30 days to try. More info about RMS can be found here (https://www.youtube.com/watch?v=1aavS-qZmNc&ab_channel=TeltonikaNetworks)
Our RMS API ( API Reference | Developers)
Or through our device API (Teltonika Networks Web API)
Please let me know if any of these solutions work for your use-case.
