If you wish to stop the outputs, you can enter the “AT+QCSQ=0” command. This command will stop the messages from the device for a while until you restart it, giving you a break from the constant stream of responses.
If there’s anything else you need help with, please feel free to ask!
Unfortunately, it is not possible to turn it off permanently. When the device restarts, all settings are reset, and the messages will start appearing again. If you need to stop the messages after a restart, you will need to enter the “AT+QCSQ=0” command each time. Thank you for understanding.
