TRB141 firmware 07.07.1
The valid description ([TRB141 Input/Output - Teltonika Networks Wiki]) mentions accessing the I/O via the /sys/class/gpio path, but unfortunately, these paths do not exist in the device.
Why?
Why?
After a firmware update, accessing I/O values via /sys/class/gpio directories was disabled. However, you can still perform the same actions using ubus commands. The wiki page you referenced provides a list of input and output pins along with their respective ubus values on the TRB141 device. This should allow you to achieve the same functionality as accessing I/O values via directories.
