TRB140 Port Forwarding Sub directory
Hi All,
Could someone advise me how / whether it is possible to Port Forward an Ip with a sub directory?
For example:
I want to access 192.168.1.10/example.html
The local port is 80, but i want to access it on 8081.
When i enter the above address into the router’s port forwarding rules, it doesn’t accept the sub directory.
Thanks in advance,
Dan
Welcome to Teltonika Networks Community !
Just needed a small clarification, you need to access 192.168.1.10:80 using the port 8081 from outside the router ?
Or you need to access 192.168.1.10:80 using 192.168.1.10:8081 in the local network ?
Just so that i can help you better.
Clive Pinto
Hi Clive,
Thank you for the reply.
I want to access it remotely.
Thanks,
Dan
