Hi
I tried factory resetting my device but this seems to have failed and it no longer boots, i have seen other threads mentioning fastboot recovery but no links seem to be active, is there any guides for this?
Hi
Hi, @don.greening
Please… Take a look at
Thanks for the reply, this was one of the threads i have tried but the link for the rootfs.ubi is not working
If the warranty is still valid for the device, we don’t recommend attempting the fastboot process, please contact your distributor to initiate the RMA process.
Hi @Justinas
I don’t believe the unit has warranty, i am happy to take responsibility if the device is bricked during recovery if you are happy to send over the files needed?
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 19132.
Thanks @Justinas
i have filled out the form.
Hi @Justinas did you receive my form?
Ive had no contact since, just want to confirm you had received it or if you need me to fill it out again?
I have sent you an email, please respond to it when you have a chance.
